HELP!!! Virus completely locked me out
Status
Not open for further replies.
ih8puters
Yesterday I found out my computer was infected with spyware and a trojan virus. I use Norton 360 which did not detect anything. My cable company actually sent me a message saying my internet settings were changed by a virus and that I needed to run my antivirus/spyware protection software. I ran norton which said it removed something but my computer was still acting funny. I downloaded AVG which I've used in the past and it found other items which were removed. My computer ran progressivly slower and slower. I could not press ctrl, alt, delete as I get a message saying the administrator has it locked. I restarted my computer and now I get a login screen saying the computer has been locked by it's administrator and will not allow me to do anything. PLEASE HELP ME. I have absolutely no idea what I am doing. I am a real estate investor and desperately need the files stored on this computer.
Thank you
G25r8cer
Have you tried booting into safe mode? When the bios page (page that says your pc make) appears repeatedly hit F8 key until a black page appears. Hit the arrow down key until "safe mode (no network)" is highlighted and hit "enter".
PCC_Australia
Sounds quite odd to say the least. You are the administrator of your computer aren't you? and you can remember the password? If not try the Windows defaults:
username: administrator or admin
leave the password field blank and hit ok or enter on your keyboard.
As for the Virus. Sometimes after a scan is completed and results are returned, it is good to take a look at the paths of the infected files and manually navigate to the folder where the assumed infected file is found and manually delete that file.
Let us know how you go, as far as accessing your desktop etc.
G25r8cer
Also. If you have both AVG and Norton installed that is BAD. You need to get rid of one of them. I recommend sticking with AVG and dump norton. Un-install norton once you get into safe mode.
ih8puters
Thank you very much for the quick reply. At the log-in screen I couldn't type anything it was "grayed" out. I rebooted the computer pressing f8 as suggested by one of the previous posts. I now have AVG running another scan and it has picked up a lot of stuff. The only thing I recognize is trojan.....I see Trojan.bomka , trojan.killproc.h , trojan.goldun.u , trojan. conhook.b , trojan.Zlob.f , Trojan.PWS.cu , etc. My computer has always ran fine until this happened yesterday. AVG has identified a lot of stuff but I'm completely ignorant about this. How do I know what I'm dealing with to even begin to remove it.
PCC_Australia
You can generally look up the definitions on any known good Anti Virus manufacturers website.
Personally, i just type the name of the virus into a google search and see whether or not the virus attaches itself to a program or frequently used file within Windows itself.
If you are unsure if the file is used alot and is a core component of daily software activites, just quarantine the file to be sure.
Hope this helps
ih8puters
is it possible to get so many virus' at once? My computer was fine until yesterday. Now AVG has a HUGE list of things
ceewi1
Post a HijackThis log:
Please download the HijackThis installer from http://www.trendsecure.com/portal/en-US/threat_analytics/HJTInstall.exe.
When the Notepad window opens choose Edit -> Select All to select the entire log, and copy and paste the log into a reply post.
Most of what it lists will be harmless or even essential, don't fix anything yet.
ceewi1
Yes, it's not unusual for an infection to download reinforcements. I suggest you spend as little time on the Internet as possible with the infected machine.
ih8puters
Scan saved at 10:16:40 PM, on 6/16/2008
MSIE: Internet Explorer v7.00 (7.00.6000.16674)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\lsass.exe
C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
C:\WINDOWS\Explorer.EXE
C:\Program Files\Microsoft SQL Server\MSSQL$VAIO_VEDB\Binn\sqlservr.exe
C:\PROGRA~1\AVG\AVG8\avgrsx.exe
C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
C:\WINDOWS\AGRSMMSG.exe
C:\WINDOWS\SOUNDMAN.EXE
C:\WINDOWS\system32\hkcmd.exe
C:\Program Files\Sony\VAIO Zone Remote Commander\AvRmtCtr.exe
C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb12.exe
C:\Program Files\HP\HP Software Update\HPWuSchd2.exe
C:\Program Files\QuickTime\qttask.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\WINDOWS\System32\Rundll32.exe
C:\PROGRA~1\AVG\AVG8\avgtray.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
C:\Program Files\InterMute\SpySubtract\SpySub.exe
C:\Program Files\HP\Digital Imaging\bin\hpqgalry.exe
C:\Program Files\Common Files\Sony Shared\VAIO Entertainment\VzRs\VzRs.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\AVG\AVG8\avgui.exe
C:\Program Files\Internet Explorer\iexplore.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
F2 - REG:system.ini: UserInit=C:\WINDOWS\system32\userinit.exe,C:\WINDOWS\system32\iftuyszv.exe,
O2 - BHO: (no name) - {00110011-4b0b-44d5-9718-90c88817369b} - (no file)
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: (no name) - {086ae192-23a6-48d6-96ec-715f53797e85} - (no file)
O2 - BHO: (no name) - {150fa160-130d-451f-b863-b655061432ba} - (no file)
O2 - BHO: (no name) - {17da0c9e-4a27-4ac5-bb75-5d24b8cdb972} - (no file)
O2 - BHO: (no name) - {1E8A6170-7264-4D0F-BEAE-D42A53123C75} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.7\NppBho.dll
O2 - BHO: (no name) - {1f48aa48-c53a-4e21-85e7-ac7cc6b5ffb1} - (no file)
O2 - BHO: (no name) - {1f48aa48-c53a-4e21-85e7-ac7cc6b5ffb2} - (no file)
O2 - BHO: (no name) - {2d38a51a-23c9-48a1-a33c-48675aa2b494} - (no file)
O2 - BHO: (no name) - {2e9caff6-30c7-4208-8807-e79d4ec6f806} - (no file)
O2 - BHO: (no name) - {467faeb2-5f5b-4c81-bae0-2a4752ca7f4e} - (no file)
O2 - BHO: targetedbanner browser optimizer - {605ce638-5c90-784e-e4e9-df9f4fc8b7f9} - C:\WINDOWS\system32\{c95a7f07-3e28-79a2-1747-96faf47f0e44}.dll
O2 - BHO: (no name) - {6cc1c91a-ae8b-4373-a5b4-28ba1851e39a} - (no file)
O2 - BHO: (no name) - {79369d5c-2903-4b7a-ade2-d5e0dee14d24} - (no file)
O2 - BHO: (no name) - {799a370d-5993-4887-9df7-0a4756a77d00} - (no file)
O2 - BHO: (no name) - {98dbbf16-ca43-4c33-be80-99e6694468a4} - (no file)
O2 - BHO: (no name) - {a55581dc-2cdb-4089-8878-71a080b22342} - (no file)
O2 - BHO: (no name) - {b847676d-72ac-4393-bfff-43a1eb979352} - (no file)
O2 - BHO: (no name) - {bc97b254-b2b9-4d40-971d-78e0978f5f26} - (no file)
O2 - BHO: (no name) - {c900b400-cdfe-11d3-976a-00e02913a9e0} - (no file)
O2 - BHO: (no name) - {cf021f40-3e14-23a5-cba2-717765721306} - (no file)
O2 - BHO: (no name) - {e3eebbe8-9cab-4c76-b26a-747e25ebb4c6} - (no file)
O2 - BHO: (no name) - {e7afff2a-1b57-49c7-bf6b-e5123394c970} - (no file)
O2 - BHO: (no name) - {fcaddc14-bd46-408a-9842-cdbe1c6d37eb} - (no file)
O2 - BHO: (no name) - {ff1bf4c7-4e08-4a28-a43f-9d60a9f7a880} - (no file)
O3 - Toolbar: Seekmo Toolbar - {53E0B6E8-A51D-448B-B692-40B67B285543} - C:\Program Files\Seekmo Programs\Seekmo Toolbar\SeekmoTB.dll (file missing)
O3 - Toolbar: Show Norton Toolbar - {90222687-F593-4738-B738-FBEE9C7B26DF} - C:\Program Files\Common Files\Symantec Shared\coShared\Browser\1.7\UIBHO.dll
O4 - HKLM\..\Run: [AGRSMMSG] AGRSMMSG.exe
O4 - HKLM\..\Run: [ATIPTA] C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
O4 - HKLM\..\Run: [High Definition Audio Property Page Shortcut] HDAudPropShortcut.exe
O4 - HKLM\..\Run: [VAIO Recovery] C:\WINDOWS\Sonysys\VAIO Recovery\PartSeal.exe
O4 - HKLM\..\Run: [SoundMan] SOUNDMAN.EXE
O4 - HKLM\..\Run: [AlcWzrd] ALCWZRD.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [IgfxTray] C:\WINDOWS\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] C:\WINDOWS\system32\hkcmd.exe
O4 - HKLM\..\Run: [VZRemoteCommander] C:\Program Files\Sony\VAIO Zone Remote Commander\AvRmtCtr.exe
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb12.exe
O4 - HKLM\..\Run: [HP Software Update] "C:\Program Files\HP\HP Software Update\HPWuSchd2.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [Symantec PIF AlertEng] "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe" /a /m "C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\AlertEng.dll"
O4 - HKLM\..\Run: [{ae452549-24f2-e1b4-220c-e7679ad1abb7}] C:\WINDOWS\System32\Rundll32.exe "C:\WINDOWS\system32\{c95a7f07-3e28-79a2-1747-96faf47f0e44}.dll" DllStart
O4 - HKLM\..\Run: [webHancer Agent] C:\Program Files\webHancer\Programs\whagent.exe
O4 - HKLM\..\Run: [AVG8_TRAY] C:\PROGRA~1\AVG\AVG8\avgtray.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [GetModule18] "C:\Program Files\GetModule\GetModule18.exe"
O4 - Global Startup: HP Digital Imaging Monitor.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe
O4 - Global Startup: HP Image Zone Fast Start.lnk = C:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe
O4 - Global Startup: Service Manager.lnk = C:\Program Files\Microsoft SQL Server\80\Tools\Binn\sqlmangr.exe
O4 - Global Startup: SpySubtract.lnk = C:\Program Files\InterMute\SpySubtract\SpySub.exe
O8 - Extra context menu item: &AOL Toolbar search - res://C:\Program Files\AOL Toolbar\toolbar.dll/SEARCH.HTML
O8 - Extra context menu item: &Google Search - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsearch.html
O8 - Extra context menu item: Backward Links - res://C:\Program Files\Google\GoogleToolbar1.dll/cmbacklinks.html
O8 - Extra context menu item: Cached Snapshot of Page - res://C:\Program Files\Google\GoogleToolbar1.dll/cmcache.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~3\OFFICE11\EXCEL.EXE/3000
O8 - Extra context menu item: Similar Pages - res://C:\Program Files\Google\GoogleToolbar1.dll/cmsimilar.html
O8 - Extra context menu item: Translate into English - res://C:\Program Files\Google\GoogleToolbar1.dll/cmtrans.html
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0\bin\npjpi150.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0\bin\npjpi150.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~3\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Real.com - {CD67F990-D8E9-11d2-98FE-00C0F0318AFE} - C:\WINDOWS\system32\Shdocvw.dll
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O10 - Unknown file in Winsock LSP: c:\windows\system32\nwprovau.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.sony.com/vaiopeople
O16 - DPF: {156BF4B7-AE3A-4365-BD88-95A75AF8F09D} (HPSDDX Class) - http://www.hp.com/cpso-support-new/SDD/hpsddObjSigned.cab
O18 - Protocol: linkscanner - {F274614C-63F8-47D5-A4D1-FBDDE494F8D1} - C:\Program Files\AVG\AVG8\avgpp.dll
O20 - AppInit_DLLs: avgrsstx.dll
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: AVG8 WatchDog (avg8wd) - AVG Technologies CZ, s.r.o. - C:\PROGRA~1\AVG\AVG8\avgwdsvc.exe
O23 - Service: Symantec Event Manager (ccEvtMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Settings Manager (ccSetMgr) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: Symantec Lic NetConnect service (CLTNetCnService) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: COM Host (comHost) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\VAScanner\comHost.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: Image Converter video recording monitor for VAIO Entertainment - Sony Corporation - C:\Program Files\Sony\Image Converter 2\IcVzMon.exe
O23 - Service: iPod Service - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: LiveUpdate Notice Service Ex (LiveUpdate Notice Ex) - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\ccSvcHst.exe
O23 - Service: LiveUpdate Notice Service - Symantec Corporation - C:\Program Files\Common Files\Symantec Shared\PIF\{B8E1DD85-8582-4c61-B58F-2F227FCA9A08}\PIFSvc.exe
O23 - Service: MSCSPTISRV - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\MSCSPTISRV.exe
O23 - Service: PACSPTISVR - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\PACSPTISVR.exe
O23 - Service: Pml Driver HPZ12 - HP - C:\WINDOWS\system32\HPZipm12.exe
O23 - Service: Sony SPTI Service (SPTISRV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SPTISRV.exe
O23 - Service: SonicStage SCSI Service (SSScsiSV) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\AVLib\SSScsiSV.exe
O23 - Service: Symantec Core LC - Unknown owner - C:\Program Files\Common Files\Symantec Shared\CCPD-LC\symlcsvc.exe
O23 - Service: VAIO Entertainment Aggregation and Control Service - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment\VzRs\VzRs.exe
O23 - Service: VAIO Entertainment Task Scheduler - Sony Corporation - C:\Program Files\Sony\vaio entertainment\VzTaskScheduler.exe
O23 - Service: VAIO Entertainment TV Device Arbitration Service - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCs\VzHardwareResourceManager\VzHardwareResourceManager.exe
O23 - Service: VAIO Media Integrated Server (VAIOMediaPlatform-IntegratedServer-AppServer) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\VMISrv.exe
O23 - Service: VAIO Media Integrated Server (HTTP) (VAIOMediaPlatform-IntegratedServer-HTTP) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\SV_Httpd.exe
O23 - Service: VAIO Media Integrated Server (UPnP) (VAIOMediaPlatform-IntegratedServer-UPnP) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\UPnPFramework.exe
O23 - Service: VAIO Media Gateway Server (VAIOMediaPlatform-Mobile-Gateway) - Sony Corporation - C:\Program Files\Sony\VAIO Media Integrated Server\Platform\VmGateway.exe
O23 - Service: VAIO Entertainment UPnP Client Adapter (Vcsw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VCSW\VCSW.exe
O23 - Service: VAIO Entertainment Database Service (VzCdbSvc) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzCdbSvc.exe
O23 - Service: VAIO Entertainment File Import Service (VzFw) - Sony Corporation - C:\Program Files\Common Files\Sony Shared\VAIO Entertainment Platform\VzCdb\VzFw.exe
End of file - 13600 bytes
ceewi1
Your system is quite badly infected.
Please download SDFix and save it to your Desktop.
Double click SDFix.exe and it will extract the files to C:\SDFix
You may wish to print out these instructions or copy them to a notepad document since you will be unable to access the Internet while in Safe Mode to read from this site.
Please then reboot your computer in Safe Mode (tap F8 just before Windows starts to load and select Safe Mode from the list).
  • Open the extracted SDFix folder and double click RunThis.bat to start the script.
  • Type Y to begin the cleanup process.
  • It will remove any Trojan Services and Registry Entries that it finds then prompt you to press any key to Reboot.
  • Press any Key and it will restart the PC.
  • When the PC restarts the Fixtool will run again and complete the removal process then display Finished, press any key to end the script and load your desktop icons.
  • Once the desktop icons load the SDFix report will open on screen and also save into the SDFix folder as Report.txt
    (Report.txt will also be copied to Clipboard ready for posting back on the forum).
  • Paste the contents of the Report.txt back on the forum in your next reply.
Please visit this webpage for instructions for downloading and running ComboFix:
http://www.bleepingcomputer.com/combofix/how-to-use-combofix
Post the log from ComboFix when you've accomplished that, along with a new HijackThis log.
Please post
  • The SDFix log
  • The ComboFix log
  • A new HijackThis log
ih8puters
Working on that now. Thank you very much for your help. Is this something that is going to be "saveable?" I was in a chat room with someone that told me to just reinstall windows.
ih8puters
I'm in safe mode running SDFix I have a black box that says:
Starting Repairs
Checking Running Processes and Services
It doesn't look like it's doing anything but I don't want to mess it up. Should something be happening on the screen? Is this a process that takes a few minutes or does it take time.
Thanks again for your help I appreciate it.
ih8puters
SDFix Log
SDFix: Version 1.193
Run by Jamie on Mon 06/16/2008 at 11:17 PM
Microsoft Windows XP [Version 5.1.2600]
Running From: C:\SDFix
Checking Services :
Restoring Windows Registry Values
Restoring Windows Default Hosts File
Rebooting
Checking Files :
Trojan Files Found:
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr0.dat - Contains Links to Malware Sites! - Deleted
C:\Documents and Settings\All Users\Application Data\Microsoft\Network\Downloader\qmgr1.dat - Contains Links to Malware Sites! - Deleted
C:\Program Files\iCheck\iCheck.exe - Deleted
C:\Program Files\iCheck\Uninstall.exe - Deleted
C:\Program Files\p2pnetworks\AlConfig.xml - Deleted
C:\Program Files\p2pnetworks\alp2plib.log - Deleted
C:\Program Files\p2pnetworks\alp2plib.log.bak - Deleted
C:\Program Files\p2pnetworks\install.log - Deleted
C:\Program Files\p2pnetworks\sp2p.cache - Deleted
C:\Program Files\p2pnetworks\uninst.exe - Deleted
C:\WINDOWS\x.exe - Deleted
C:\WINDOWS\y.exe - Deleted
C:\WINDOWS\accesss.exe - Deleted
C:\WINDOWS\astctl32.ocx - Deleted
C:\WINDOWS\avpcc.dll - Deleted
C:\WINDOWS\clrssn.exe - Deleted
C:\WINDOWS\cpan.dll - Deleted
C:\WINDOWS\ctfmon32.exe - Deleted
C:\WINDOWS\ctrlpan.dll - Deleted
C:\WINDOWS\default.htm - Deleted
C:\WINDOWS\directx32.exe - Deleted
C:\WINDOWS\dnsrelay.dll - Deleted
C:\WINDOWS\editpad.exe - Deleted
C:\WINDOWS\explore.exe - Deleted
C:\WINDOWS\explorer32.exe - Deleted
C:\WINDOWS\funniest.exe - Deleted
C:\WINDOWS\funny.exe - Deleted
C:\WINDOWS\gfmnaaa.dll - Deleted
C:\WINDOWS\helpcvs.exe - Deleted
C:\WINDOWS\iedll.exe - Deleted
C:\WINDOWS\iexplorer.exe - Deleted
C:\WINDOWS\inetinf.exe - Deleted
C:\WINDOWS\internet.exe - Deleted
C:\WINDOWS\loader.exe - Deleted
C:\WINDOWS\msconfd.dll - Deleted
C:\WINDOWS\msspi.dll - Deleted
C:\WINDOWS\mssys.exe - Deleted
C:\WINDOWS\msupdate.exe - Deleted
C:\WINDOWS\mswsc10.dll - Deleted
C:\WINDOWS\mswsc20.dll - Deleted
C:\WINDOWS\mtwirl32.dll - Deleted
C:\WINDOWS\notepad32.exe - Deleted
C:\WINDOWS\olehelp.exe - Deleted
C:\WINDOWS\qttasks.exe - Deleted
C:\WINDOWS\quicken.exe - Deleted
C:\WINDOWS\rundll16.exe - Deleted
C:\WINDOWS\rundll32.vbe - Deleted
C:\WINDOWS\searchword.dll - Deleted
C:\WINDOWS\sistem.exe - Deleted
C:\WINDOWS\svchost32.exe - Deleted
C:\WINDOWS\svcinit.exe - Deleted
C:\WINDOWS\systeem.exe - Deleted
C:\WINDOWS\systemcritical.exe - Deleted
C:\WINDOWS\system32\hljwugsf.bin - Deleted
C:\WINDOWS\system32\pac.txt - Deleted
C:\WINDOWS\time.exe - Deleted
C:\WINDOWS\users32.exe - Deleted
C:\WINDOWS\waol.exe - Deleted
C:\WINDOWS\win32e.exe - Deleted
C:\WINDOWS\win64.exe - Deleted
C:\WINDOWS\winajbm.dll - Deleted
C:\WINDOWS\window.exe - Deleted
C:\WINDOWS\winmgnt.exe - Deleted
C:\WINDOWS\xplugin.dll - Deleted
C:\WINDOWS\xxxvideo.hta - Deleted
Folder C:\Program Files\GetModule - Removed
Folder C:\Program Files\iCheck - Removed
Folder C:\Program Files\p2pnetworks - Removed
Removing Temp Files
ADS Check :
Final Check :
catchme 0.3.1361.2 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-06-16 23:30:23
Windows 5.1.2600 Service Pack 2 NTFS
scanning hidden processes ...
scanning hidden services & system hive ...
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\MUILanguages\RCV2\clb.dll]
"0"=hex:00,00,28,0a,01,00,05,00
"1"=hex:b6,00,b6,eb,2f,6b,03,cb,5a,e8,c3,ac,b9,40,38,e1
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\MUILanguages\RCV2\clbcatex.dll]
"0"=hex:2a,00,3e,11,0c,00,d1,07
"1"=hex:cf,24,2a,85,a4,d7,fe,3c,03,76,96,fe,18,b6,ec,d3
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\MUILanguages\RCV2\clbcatq.dll]
"1"=hex:6a,b7,9d,1d,7d,d8,1d,46,23,79,12,2a,da,6a,19,42
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\clbdriver.sys]
@="driver"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\clbdriver.sys]
@="driver"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\clbdriver]
"type"=dword:00000001
"start"=dword:00000001
"imagepath"=str(2):"\??\globalroot\systemroot\system32\drivers\clbdriver.sys"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Nls\MUILanguages\RCV2\clb.dll]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Nls\MUILanguages\RCV2\clbcatex.dll]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\Nls\MUILanguages\RCV2\clbcatq.dll]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\SafeBoot\Minimal\clbdriver.sys]
@="driver"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Control\SafeBoot\Network\clbdriver.sys]
@="driver"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet002\Services\clbdriver]
scanning hidden registry entries ...
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\clbImageData]
"affid"="7"
"subid"="c001"
"control"=hex:1a,00,15,13,07,11,18,1f,14,0a,49,09,4b,1a,09,50,11,e5,f5
"prov"="10010"
"googleadserver"="pagead2.googlesyndication.com"
"flagged"=dword:00000001
scanning hidden files ...
C:\WINDOWS\$hf_mig$\KB902400\SP2QFE\clbcatex.dll 110080 bytes executable
C:\WINDOWS\$hf_mig$\KB902400\SP2QFE\clbcatq.dll 498688 bytes executable
C:\WINDOWS\system32\clb.dll 10752 bytes executable
C:\WINDOWS\system32\clbcatex.dll 110080 bytes executable
C:\WINDOWS\system32\clbcatq.dll 498688 bytes executable
C:\WINDOWS\system32\clbdll.dll 43520 bytes executable
C:\WINDOWS\system32\clbinit.dll 1693 bytes
C:\WINDOWS\system32\drivers\clbdriver.sys 10240 bytes executable
C:\WINDOWS\$NtUninstallKB902400$\clbcatex.dll 110080 bytes executable
C:\WINDOWS\$NtUninstallKB902400$\clbcatq.dll 501248 bytes executable
scan completed successfully
hidden processes: 0
hidden services: 1
hidden files: 10
Remaining Services :
Authorized Application Key Export:
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\standardprofile\authorizedapplications\list]
"%windir%\\system32\\sessmgr.exe"="%windir%\\system32\\sessmgr.exe:*:enabled:mad:xpsp2res.dll,-22019"
"C:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe"="C:\\Program Files\\Common Files\\AOL\\ACS\\AOLacsd.exe:*:Enabled:AOL"
"C:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe"="C:\\Program Files\\Common Files\\AOL\\ACS\\AOLDial.exe:*:Enabled:AOL"
"C:\\Program Files\\America Online 9.0\\waol.exe"="C:\\Program Files\\America Online 9.0\\waol.exe:*:Enabled:America Online 9.0"
"C:\\Program Files\\p2pnetworks\\p2pnetworks.exe"="C:\\Program Files\\p2pnetworks\\p2pnetworks.exe:*:Enabled:p2PNetworks"
"C:\\Program Files\\LimeWire\\LimeWire.exe"="C:\\Program Files\\LimeWire\\LimeWire.exe:*:Enabled:LimeWire"
"%windir%\\Network Diagnostic\\xpnetdiag.exe"="%windir%\\Network Diagnostic\\xpnetdiag.exe:*:Enabled:mad:xpsp3res.dll,-20000"
"C:\\Program Files\\iTunes\\iTunes.exe"="C:\\Program Files\\iTunes\\iTunes.exe:*:Enabled:iTunes"
"C:\\Program Files\\AVG\\AVG8\\avgupd.exe"="C:\\Program Files\\AVG\\AVG8\\avgupd.exe:*:Enabled:avgupd.exe"
[HKEY_LOCAL_MACHINE\system\currentcontrolset\services\sharedaccess\parameters\firewallpolicy\domainprofile\authorizedapplications\list]
Remaining Files :
File Backups: - C:\SDFix\backups\backups.zip
Files with Hidden Attributes :
Mon 13 Sep 2004 54,384 A..H. --- "C:\Program Files\America Online 9.0\aolphx.exe"
Mon 13 Sep 2004 156,784 A..H. --- "C:\Program Files\America Online 9.0\aoltray.exe"
Mon 13 Sep 2004 31,344 A..H. --- "C:\Program Files\America Online 9.0\RBM.exe"
Mon 21 Aug 2006 4,348 A.SH. --- "C:\Documents and Settings\All Users\DRM\DRMv1.bak"
Mon 31 May 2004 77,824 A..HR --- "C:\Documents and Settings\Miranda\Local Settings\Temp\hpbinsmg.dll"
Wed 7 May 2008 0 A..H. --- "C:\WINDOWS\SoftwareDistribution\Download\385cb67dda0ffd4dea8c0d990dc65796\BIT3.tmp"
Finished!
ih8puters
I can't get combofix to run. I've followed the directions on the link provided exactly and I do not get the blue box.
Here is the latest Hijackthis log. I must say my computer is running better already. Minus the popup ads
Scan saved at 00:05, on 2008-06-17
Boot mode: Normal
Running processes:
End of file - 11811 bytes
cohen
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
Note: Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Combofix should never take more that 20 minutes including the reboot if malware is detected.
If it does, open Task Manager then Processes tab (press ctrl, alt and del at the same time) and end any processes of findstr, find, sed or swreg, then combofix should continue.
If that happened we want to know, and also what process you had to end.
ceewi1
It's fixable but will be difficult. You have a rootkit which can interfere with ComboFix. I need you to download a new version, but rename it to something else which should avoid being stopped by the rootkit. I suggest you follow only my instructions in this thread.
Please delete your copy of ComboFix, and download the latest version from here.
NOTE: When you download ComboFix.exe, rename it like so:
  • Double-click Combo-Fix.exe, and follow the prompts.
  • When the tool is finished, it will produce a report for you.
  • Please post the C:\ComboFix.txt along with a new HijackThis log.
Status
