Graphics card does matter a lot in gaming, Dual NVIDIA GeForce GTX 480(3 GB) is the best one.
Don't buy Radeon HD, it sucks. NVIDIA is the best....
Processor: Intel Core i7 980X
RAM: 3 or 4 GB
Board: Gigabyte X58 UD5
Others specs. i think does not matter much
RAM: 3 or 4 GB
What's the budget? There's no definition of "best of the best" computers. I'm sure you can easily build a computer into the $10,000+ range if you wanted to (quad xenon processors for workstation, 4 way SLI for gaming, 16GB of ram, RAID 0 SSDs etc etc).
10,000 $ + range thats like too much for gaming
can i try for i7 930M with windows 7 for latest and top games
my budget is not more than 2k $
which would be the best graphic card
I don't know shorts like GPU and GTX. what are those?GPU in that range you'd be looking at HD 5870/GTX480
RAM: 3 or 4 GB
^ yep
4xHD5970 would be better for gaming, but whatever, excellent point:good:
The best of the best.. a 980x with phase change, 24gb of ram, a shitload of ssds and hard drives, 4 gtx 480s, 4 more phase change units for the gpus, and giant power supply or two. Lol
RAM: 3 or 4 GB
RAM: 3 or 4 GB
If you want to save 700 bucks, i'd get the AMD phenom II x6 1090 black edition cpu for 300. 2tb hd's, 12x optical, full tower case, 1 or 2 5970's, gigabyte ud7 mobo, 1000w psu, and some good cooling are a few ideas. Research though man until you find out what you want in each component, and then you can make your mind up a bit better. Read specs thoroughly.
only 2 max. can't do octa-fire yet.
