The best of the best PC
Ankur
I am buying a new Desktop PC now, what should specification should I consider purchasing so that it becomes the best of the best and better than the rest.
Ankur
Hardcore Gaming, programming in C and C++, lots of multitasking etc
but mostly for gaming
sat
Graphics card does matter a lot in gaming, Dual NVIDIA GeForce GTX 480(3 GB) is the best one.
Don't buy Radeon HD, it sucks. NVIDIA is the best....
Processor: Intel Core i7 980X
RAM: 3 or 4 GB
Board: Gigabyte X58 UD5
Others specs. i think does not matter much :)
Russ88765
RAM: 3 or 4 GB
Radeon sucks? Their cards are still superior in performance to Nvidia's. They come in 2 or 4gb capacity, and it would take 2 or 3 gtx480's to match them. In the laptop realm, nothing beats 2 gtx480's though- Radeon still hasn't made an equal competitor.
diduknowthat
formerly liuliuboy
What's the budget? There's no definition of "best of the best" computers. I'm sure you can easily build a computer into the $10,000+ range if you wanted to (quad xenon processors for workstation, 4 way SLI for gaming, 16GB of ram, RAID 0 SSDs etc etc).
fastdude
RAM: 3 or 4 GB
What are you on about? For i7-980X, you want triple channel RAM, so 3GB or 6GB or 12GB or whatever. There are better X58 mobos than UD5. how can you say Radeon HD sucks? Could you answer please?
fastdude
^ yep
4xHD5970 would be better for gaming, but whatever, excellent point:good:
Ankur
10,000 $ + range thats like too much for gaming
can i try for i7 930M with windows 7 for latest and top games
my budget is not more than 2k $
which would be the best graphic card
fastdude
i7 930M is mobile CPU. 930 is desktop version. GPU in that range you'd be looking at HD 5870/GTX480
Sluggo
I don't know shorts like GPU and GTX. what are those?
A GPU is a graphics processing unit..aka your video card or graphics card. GTX is part of the naming scheme used by nvidia when naming some of there cards. A GTX480 is a type of video card made by nvidia.
joh06937
RAM: 3 or 4 GB
ha ha, fail...
^ yep
only 2 max. can't do octa-fire yet.
$2000 is a great budget. give me a minute here to find some stuff for you :p
cpu
motherboard
ram
hdd
psu or psu
case nobody ever seems to recommend this one but i think it looks pretty awesome :good:
heatsink
gpu or gpu or gpu i'd go with either the 5870 or 5970 personally.
with the xfx psu and the 5870, total is $1500 which gives you plenty of room for an ssd if you want.
The best of the best.. a 980x with phase change, 24gb of ram, a shitload of ssds and hard drives, 4 gtx 480s, 4 more phase change units for the gpus, and giant power supply or two. Lol
$2000 budget.
computeruler
Moan
RAM: 3 or 4 GB
what's wrong with Radeon ????
Russ88765
If you want to save 700 bucks, i'd get the AMD phenom II x6 1090 black edition cpu for 300. 2tb hd's, 12x optical, full tower case, 1 or 2 5970's, gigabyte ud7 mobo, 1000w psu, and some good cooling are a few ideas. Research though man until you find out what you want in each component, and then you can make your mind up a bit better. Read specs thoroughly.
Aastii
RAM: 3 or 4 GB
1. For the best, you wouldn't get a 980x, you would get dual Xeons
2. Memory should be triple channel, and much more than 4GB for "the best"
3. Regarding the motherboard, see point 1
4. Back up reasoning for "Radeon sucks" other than fanboyism? I know alot of people on here, myself included, use ATi and have no problems doing anything...
5. Other specs do matter. Power supply matters more than anything, the choice of hard drive(s) matters a lot, cooling and cases matter a lot.
Phenom II x6 is pointless for a gaming rig. No games utilize hex core fully yet, and when they do Thuban will be outdated.
Mobo + CPU: http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.501338 $483
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304 $140
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009 $120
Main drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227550 $150
Storage: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136514 £120
Graphics: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102887 $600
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160 $130
CPU Cooling: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103089 $70
DVD Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135224 $18
OS: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754 $100
Total: $1931
I wouldn't be surprised if there are better deals, places money could be saved etc, that rig was only thrown up fairly quickly. However, it will do every single thing that you want, and will do it very, very quickly
BillOhio
Is it possible to 'Tri-Fire' via a 5870 with 1 5970?
Edit: I'm reading that you can X-fire any 2 ATI cards but that the cards will automatically be set to the clock speed that is the slower of the 2 cards. Does that sound right?
