Bios Problem, Help Please!?
Discussion in 'Motherboards' started by hypojam, Dec 31, 2007.
  1. hypojam
    hypojam New Member
    111
    Hi, everytime i boot my computer it says 'there is not enough space in the runtime area, smbios data will not be available'
    What does this mean, ive only just built this computer and i am dissapointed that crap like this is happening.
    My Mobo is a MSI K9N6SGM-V
  2. massahwahl
    massahwahl VIP Member
    4,816
    Ill try to help you out but im not very knowledgable about bios. How much ram do you have first of all?
  3. hypojam
    hypojam New Member
    111
    1gb But this issue isnt related to the RAM as far as im aware, some kinda bios issue
  4. massahwahl
    4,816
    Have you installed an OS yet? Or is this as far as you can get period? Also, what bios version do you have right now?
  5. massahwahl
    4,816
    You may want to try removing the battery on the motherboard for a minute or so and removing and reseating the ram sticks, see if that has any affect.
  6. tremmor
    tremmor Active Member
    6,299
    i built a msi motherboard years ago.
    this board might not have a battery.
    might have to take off a jumper.
    just a thought .
  7. massahwahl
    4,816
    True, never thought about that.
  8. hypojam
    hypojam New Member
    111
    Yep installed windows xp, 3dmarked it and its performing just as it should, ive tried resetting the bios, unplugging everything(hdd.cdrom ect..), tried everything possible bios wise to try and fix this but the error just always come back
    beeps twice and says 'there is not enough space in the runtime area, smbios data will not be available'
  9. massahwahl
    4,816
    So you have no way of getting into windows? Might be a good idea to give MSI a call and see what they have to say
  10. hypojam
    hypojam New Member
    111
    No No, the board is performing as it should. Just that initial error comes up and its something to do with the bios, what i want to know is how to stop it coming up
  11. massahwahl
    4,816
    If you can get into windows, then I would see if there is an update available to flash your bios. That should take care of it.
  12. hypojam
    hypojam New Member
    111
    Tried that of the msi live update thing, it already said the bios was up to date, what im considering is flashing the bios with a floppy disk maybe with an older bios version
  13. massahwahl
    4,816
    That may work, have you tried removing the battery or resetting the jumper first though?
  14. hypojam
    hypojam New Member
    111
    yes
  15. massahwahl
    4,816
    Try your idea then and see what happens. Let us know!
Share This Page
