Hello,
I have had the same setup working perfectly for over a year. Three weeks ago I turned on my computer, all was fine, came back hours later to find the computer off but the desktop case/fans and power supply were lit up and spinning slower than normal. I toggled the power switch on the PS (Corsair 600W) and then proceeded to start the computer again but it would not start. No response at all except the green light on the motherboard would remain lit. I tried plugging it into another desktop with the same result so I concluded the PS died on me.
I shipped it to Corsair. In the meantime I purchased a backup PS (Dynex 520W) on eBay and installed it and everything works fine.
Fast forward to present day when I received the new Corsair replacement. I take out the Dynex, replace it with the Corsair, and again the computer will not start. This time the PS will begin spinning (sometimes the light will flash on) for only ~1 second. It will only do this once however, I have to physically unplug/replug the power cord for this result to reappear. No the Dynex is back in.
Any ideas? Could I really have received a bad replacement power supply, or am I missing something?
Thank you!
Matt.
Thank you!
Matt.
