Monitor problem
Discussion in 'Video Cards and Monitors' started by Shane, Mar 6, 2008.
  1. Shane
    Shane Super Moderator Staff Member
    20,433
    Hey,
    I have this monitor:
    22" Belinea 0 Display LCD 5ms
    http://www.cclonline.com/product-info.asp?product_id=18486&category_id=364&manufacturer_id=0
    this past week i have not been able to turn the monitor off while the pc is running like usualy if im downloading and i want to go out i will leave my pc running but just turn off the monitor but i cant because when i press the monitors power button i get a message on the screen that says:
    Any help appreciated.
  2. cohen
    cohen New Member
    8,364
    Sounds like it is a problem with the button on the inside of the monitor.
    So you might have to open it up and have a look or buy a new one.
  3. TFT
    TFT VIP Member
    5,242
    It's not a problem with the button it's a feature to stop accidently turning the monitor off. This is set in the OSD menu which can also be locked.
  4. Shane
    20,433
    wheres that OSD menu mate i have no clue.
    i dont know why its locked because i havnt been messing about with any of my monitors buttons or anything.
    it just wouldnt switch off since Monday :mad:
  5. TFT
    TFT VIP Member
    5,242
    Try these options, they are'nt for your LCD and the wording/symbols may be different but may unlock your buttons, if not try a few combinations, you get the idea.
    Option 1: OSD lock - all 4 buttons are locked except the "POWER"
    button. Press and hold the "MENU" and ">" buttons for 3
    seconds to lock the buttons. Repeat this step to unlock.
    Option 2: OSD & Power button lock - all 5 buttons including the
    "POWER" button are locked. Press and hold the "MENU"
    and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
  6. Shane
    20,433
    compleatly forgot about this post, itried turning my monitor off just and got the damn message again.
    this worked...
    tks so much man ;)
Share This Page
