Problem with my sound card?
Discussion in 'Desktop Computers' started by ladysingsthblus, Apr 9, 2008.
  1. ladysingsthblus
    ladysingsthblus New Member
    5
    My speakers work fine, yet when I play music or video no sound comes out. When I turn the volume up high though, I can still hear the white noise. Do I need to reset my sound card?
  2. cohen
    cohen New Member
    8,364
    What sort of sound card do you have???
    Is it on the motherboard???
    Or is it another card???
  3. ladysingsthblus
    5
    That's the thing. I have no idea. All I know is that the speakers work in other computers and media and they worked the first time I plugged them into mine. But the last time I restarted my computer, they no longer worked. And yes, I've since tested them and they work fine.
  4. Deviousmind
    Deviousmind Member
    422
    You tried looking at the settings in volume control?
  5. ladysingsthblus
    5
    Yes, first thing. Nothing is muted, all bars are up.
  6. Deviousmind
    Deviousmind Member
    422
    Have you been into device manager to see if all drivers are installed no yellow ?s
  7. ladysingsthblus
    5
    I'm not sure how to do that, which is why I'm posting here. Can you give me instructions?
  8. cohen
    cohen New Member
    8,364
    Start > Right-Click on my computer > Manage > Device Manager > Sound, Video & Game Controllers.
  9. diduknowthat
    diduknowthat formerly liuliuboy
    9,267
    Check to see if the correct audio device is enabled in your Audio panel in the control panel.
  10. ladysingsthblus
    5
    The following options appear when I click on Sound, Video & Game Controllers:
    -Audio Codecs
    -Crystal SoundFusion(tm)
    -Crystal WDM Audio Codec
    -Crystal WDM Audio Control Registers
    -Crystal WDM Game Port
    -Crystal WDM MPU-401 Compatible
    -Legacy Audio Drivers
    -Legacy Video Capture Devices
    -Media Control Devices
    -Video Codecs
  11. Deviousmind
    Deviousmind Member
    422
    ok all seems fine there as long as no yellow question marks against any entry can i ask wot o/s your using and if this is happening in windows media player 11
Share This Page
