BC2 Sound issues.
Shane
Super Moderator
Hey guys,
Im clueless to whats going on with the sound in BC2,I cannot hear Mcom station alerts,I cant hear that noise you get when you give someone ammo or health either.
Also,When im moving around i can hear certian things but if i turn to the right for example the sound cuts off,Ive tried the diffrent audio settings for BC2,Ive tried diffrent audio settings in the Xonar control panel and still the same.
Anyone have any ideas? Its really frustrating.:(
funkysnair
are you using 5.1 headset? if so have you tried plain and simple stereo sound?
does this problem happen in other games?
Shane
Super Moderator
This started happening for no reason?
Yes...its happened before,Then it went back to normal and now its playing up again.
Im running 5.1 on my logitech speaker system,although i have my headphones plugged into the logitechs volume pod thingy.
Nope does not happen in any other game,Just BC2.
uninstall and reinstall always seems to work when my games mess up
Already tried. :(
funkysnair
you tried going into your sound in control pannel and disabling things that you do not use?
i have read this somewhere (over a rainbow)
Shane
Super Moderator
Yeah ive tried every setting in the Xonar control panel,Nothing changes.:eek:
Edited the games .ini settings and changes my speaker count,Still the same. :(
Shane
Super Moderator
Just tried Far Cry 2 Map editor,and while moving around and explosions the sound is also not right in that game,it cuts out if i turn to one side.....any help appreciated.
Shane
Super Moderator
Ive tried every setting mate,Nothing made any diffrence,However i have sorted the problem.
Ive just plugged my Headphones directly into my sound card at the back,Instead of going through my Logitech system.
I shouldnt have too,But i just cant be bothred anymore find out what is really the problem...98% of the time im using my Headphones anyway so..
