ZachSand
So I've had quite a bit of trouble with the Xbox 360's being that I've had to return 2 to be fixed.
In this case they sent me back a brand new 360, because they couldn't seem to fix mine.. or something along those lines.
I've had it for quite a while now, and it's out of warranty. Just recently(Past 3 months) it's started to(sometimes) light up either one, two, or all 3 red rings. It seems spontaneous to which one it chooses to be the problem. I'll usually turn it on and off a few times and wait then try again later, and sometimes it ends up working very smoothly.
Sometimes when i turn it off, the lights+audio/visual, basically everything goes off, yet something inside of it seems to still be on because it makes the same noise as when it is on. Which makes me have to unplug it.
There is probably some site I can go to find out/fix the problem, does anybody know what site, or have any suggestions?
