Can this computer run call of duty: modern warfare 3?
A Gamer
CPU speed: 3.6 GHz
Cores: 4
Memory: 8 GB
Hard drive: 1 TB
CD / DVD: CD + DVD writer
Brand new custom built QUAD Core PC
AMD FX-4100 [X4] 3.6GHz CPU
> (4x3.6GHz=14.4GHz)
8GB DDR3
AMD HD3000 (760G/780L) onboard graphics (D-Sub)
1000GB (1TB) HDD for OS/Storage
DVD±RW dual layer ODD
Raidmax Tornado gaming case with 2 cooling fans and 500W PSU
STANDARD SOFTWARE
Adobe Reader 10
AVG Free 2012 antivirus
Can download any needed software from internet
If it is able to, it'd be on the lowest settings possible. It would still probably run to slow for you to enjoy it.
EDIT: You'll want to add a graphics card to your machine, then it will run games just fine.
So you haven't bought this computer yet? If not then where are you buying it from? If it's a pre-built machine then it will more then likely come with crap components, particularly the power supply. 500 watts is okay as long as it's not a pos.
