Requirements question
wolfeking
banned
Okay, I have a screen from can I run it showing what it calls for and what I have, but my question is how accurate it is. Basically, I get that I can play it, but is it only going to run at a minimum level that will look like crap? I really don't want to waste the space if it will only run at minimum levels.
Hmm looks like it'll be OK, may only play at low-medium settings though. What game is it?
Crysis of coarse. lol.
I'm sure somebody more knowledgeable than myself will correct me if I am wrong, but I'd say it would only play at low or medium with decent FPS. Wouldn't expect anything more than medium unless you have a tiny tiny resolution.
You'll be able to play it on low settings, but I'm not sure you'll be able to play on medium, only if you lower your resolution. The graphics will be more crappy on medium and a low res, then low settings on an higher res.
