speedyink said:has anyone here tried it?
I heard that the xbox 360 controller could be plugged into a PC. Is this true? Has anyone tried it? If so how does it work? I was thinking of buying an xbox 360 controller for my computer instead of the Logitech one.
Raditz said:I'm probably going to do the same thing instead of getting a joy stick. I'll let know you if I tried.![]()
speedyink said:too late, bought the 360 controllerIt actually works pretty good with the PC. super easy install.
the wireless one will only work if you buy an signal thing that is suppose to go with it I havent seen one to buy but I did checkout some site that had pics of it but I don't belive it is out yetya, i would like to know to if its possible to use the wirless one. Bump!
the wireless ones are also USB![]()
