I've got a home made rig here that is excessively noisy. The sound that the tower produces is so loud that if I want to read in the room I have to put ear plugs in. Oddly enough, the sound appears to be coming from a fan that was advertised as a specialty, near silent unit. I would like to slow down the fan to the point at which it becomes bearable, but I don't wish to put my system in jeopardy of over heating.
I checked out the bios and found these specs
42 Celsius- System Temp
43 Celsius- CPU Temp
Fan Speed- 4590 RPM
CPU fan speed- 0 RPM
Northbridge Fan- 8766 RPM
I suspect that the CPU fan sensor is either not working properly or is nonexistent, so I'm not too worried about that. The other two fan speeds seem excessively high though.
How should I go about quieting down my system without burning it up?
Thank you!
Fan Speed- 4590 RPM
Thank you!
