Well
1. you only have 1GB of RAM. Even though it recommends that much, that FREE RAM, not total, cuz then It wants 1 GB but other applications are using it, so maybe only get 730MB...But you can lower that setting if you must.
2. lower any setting that makes a lot of stress on the computer
3. A really good Hard drive can help load textures fast.
FEAR is a great game, but does anybody know why it can get so choppy? Everytime I turn a corner the game gets very choppy, and while doing this the hard drive seems to be very busy. I'm thinking it has something to do with the hard drive... what do you think?
[-0MEGA-];603682 said:Ryan, is this new or has it been happening all the time?
Are you playing it with max settings? Try killing AA and see if it still lags.
[-0MEGA-];603682 said:1
3. Hard drives only effect loading times.
Uh no. If His RAM runs out then the game will write info on the hard drive if it needs to. A slow hard drive can cause more lag then a fast one in this case. Believe me, I had to do it like this at one time.OH, and according to me G15, the game does actually take 1GB away from me.
Also, under the computer part of the options, lower settings in there where it concerns RAM.
Because all your other apps that werent in high demand were moved to the page file.I don't know if this is helpful, but I minimized the game during play and my PF usage was at 1.16GB.
[-0MEGA-];604486 said:How much RAM does it say FEAR is using when you ALT TAB it?
