Test Drive Unlimited ... Any Good?
Jbenekeorr
I have just ordered test drive unlimited for PC from play.com, i already have the PS2 version, i understand that it has more features in the PC version, does anybody know if it is a good game for PC?
P.S I guess i should have asked this before i ordered it!
You should invest in a new one, i might run it a ultra LOW settings but i would realy try and get a new one. Something on the cheaper end of the scale like a 7600-7900GS would be good
Joystick?
Could i use a joystick on TDU like a steering wheel? By programming accelerate to be push forward and steering left to right e.t.c :confused:
Yes you are right it has some extra feature that you can't see on ps2 .
But don't forget that you should have a super computer to run it smoothly!!
yea thanks for the uneeded info
TBH i wouldn't need to put that if you had bothered to check the dates in the first place :rolleyes:
so really your info was unneeded coz he must have got it working other wise he would have asked about it in the month he has had it
who cares its amercian i can do wat i want to do
With my video card i can max that game out and max AA without a bit of lag. Graphics are nice in that game.
The X8** series are great cards, I have the X850 Pro, simple AMAZING!
well my bro has a custom computer 2.8 ghz great video card and 2 gb and it still lags go figure
Doesn't that just back up what I've said, I'll say it again... "You make it sound as if they're high specs". The X8** series cards are great, if he has one of them, it's good!
That doesn't make sense.
