[Asus x399-A Threadripper] ER_LED4 ? Motherboard wont boot. Possiblr pcie damage?
QLofLandfill
Hey so I was shutting down my computer to install a pcie wifi Card. My computer is at eye level so I had it opened up I was waiting for it to turn off my hand twitched a little the pcie cards metal tapped the pcie slot and it seemed to havr shorted out....ever since neither the power button on the tower or MOBO do anything at all.
Things I've tried and notable stuff
1. The light for the SB_PWR is the only consistent light when I have power running to the computer.
2. The ER_LED4 light flashes quickly as I power it on sometimes.. (I can't find anything about this in the manual or online, I assume its for debugging and to tell if there's an error with the hardware on the pcie slot...but not sure)
3.ive tried all regular troubleshooting...removed everything right down to the fans reseated all the main components including cpu and power supply. No change
I'm kinda guessing my motherboards completely fried and I shorted it out at this point but any other opinions? Thoughts?
ASUS X399-A Threadripper
Hey, sorry to hear about the trouble you're having. It does sound like you may have shorted out the motherboard, especially given the symptoms you’re describing.
Since the SB_PWR light is on, the board is getting some power, but the fact that it won’t fully boot and the ER_LED4 flashes points to a potential issue with the hardware. Unfortunately, shorting the PCIe slot while the system is powered on can definitely cause damage to the motherboard or other components.
Here are a few things you could try before writing it off completely:
  1. Clear CMOS: Try resetting the CMOS to see if that helps—sometimes a short can mess with the BIOS settings.
  2. Check for Visible Damage: Inspect the PCIe slot and other components for any visible signs of damage (burn marks, bent pins, etc.).
  3. Test PSU: Even though the light comes on, it’s worth testing the power supply with another system or using a power supply tester, just to rule out any PSU-related issues.
If these steps don’t work, it’s likely that the motherboard is damaged, but it’s always good to double-check before assuming the worst. Hope this helps!
Appreciate the response! Yea I've tried most of that although I don't really have a separate setup to test the PSU with I just bit the bullet and spent money I don't have on a new motherboard...ugh
One more question though.
If I got the exact same motherboard would I need to start with a fresh install of windows? Or am I able to just connect all my components to the new board and turn it on like nothing happened? Would there be a high potential for system instability?
Should be okay, it might or might not harass you to reactivate Windows.
Modern versions like 10 and 11 are much better at transplanting into different systems than previous versions even if the hardware is a little different, the same board should be fine just as above the ID of the board will change.
Awesome ty. Hopefully this fixes the issue. Should get it next week. But yea upon closer inspection all ER_LED lights flash on startup. (ER_LED1, 2, 3, 4 ETC) so I'm pretty positive I fried the board. Brutal lol...well who knows when I take it apart I have a soldering kit might be a good project to see if I can pinpoint it and maybe fix. Highly doubtful but why tf not
Ohhh last question I do have another motherboard with bent pins on the cpu slot. Is it possible to swap out the cpu insert with a new one or is the whole board just screwed?
Self soldering an entire socket? Good luck.
Sometimes you can fix the pins with huge amount of patience and a steady hand, depends if an entire bank is smashed or just a couple.
Ooof. Depends on how bad it is, it could be fixed with some basic hand tools.
If you have access to the socket's pin map and you can correlate it to the pin map, you can at least check to see if that pin's used for anything. Sometimes they're just extra ground pins that might not be a problem if they're not making contact.
Replacing sockets is not really a DIY thing.
Not a huge issue was. I got a new board coming at least. Just have a damaged board with bent pins. Quite a few of them are screwed. Attempted to fix it before in poor lighting and just bent more lmao someone gave me this one though
Well just an update. After buying two aftermarket boards, one exactly like my old one and an asrock taichi, I came to the confusion I fried my cpu as well.
Devastated I said screw it and threw 50 bucks at the casino where I somehow win $2k
So new build is a ryzen 5900x and an Asus Tuf Gaming B550-PLUS for my mobo. All of my current ram etc should hopefully work....thank you universe....
*disclaimer* don't gamble you will lose everything, I promise *end disclaimer*
Figured id post an update in case anyones ever googling a similar issue and stumbled across this over the years...everything's working now (I bought a new cpu and mobo it better)
So initially I bought the same board aftermarket on ebay . Spent a day putting it all together anddd...DRAM errors Non stop.
Returned the board thinking either my cpu was fried as well as the mobo or the replacement mobo was faulty.
Bought ANOTHER mobo on Facebook marketplace and it didn't work either..
Figured okay 2 in a row the cpu must be fried after some research...
So won the money I mentioned bought a ryzen5900x and an asus tuf gaming b550-plus (WI FI II) off of new egg.
Once it was together turn it on andddd. DRAM ERRORS!!!!
So I pulled all of the power cables except the main cables from the power supply. So only power to the board. I turned it on and other than it screaming in terror at me from having no drives or anything else it turned on.
I plugged it all back in and it worked...then I noticed that one of the ports in the PSU had melted. So when I fried the original mobo it must havr melted that port. That was the port I had the EATX12V 8 pin connector for the secondary power to the mobo connected in..
So I'm guessing my old cpu is probably fine and the first board would have worked and i spent a whOle lot of money, i would say for nothing (some was), although I got a pretty decent upgrade from my 1950x threadripper and prime x399 mobo...so I dunno stress is over now...
Thanks for the help!
