cooling without fan
Lorand
<b>VIP Member</b>
How about putting the components inside of a mini-bar fridge? It’s cheaper than a Vapochill case... ;)
tristan
why not use fans? they are reletively cheap, can be bought silent, and dont use much power?
Maybe describe the problem or what you are trying to do and I can help you out. Im pretty good at coming up with fabrications
arno
wel im just bored and i wanted to make something that cools the computer down because my old won isnt worght buying some fans and i used a old power supply fan that a friend gave me to cool it down sow that was cheap :D
Flash_AAA
hmmm how about running a line from your AC to your computer? What about dry ice dropped at slow intervals?
DISCLAIMER:
I'm not reponsible for :eek: ... lol
Praetor
Administrator
Be much easier to use more "standard" methods cuz the AC isnt to great in the winter :p
pipit
no winter in here.... in fact, it feels like inside oven now.
maybe it can use for computer in here........^joking^ :D
Praetor
Administrator
Yeah it would definitely require some serious studying to implement a noiseless case in that kinda environment :)
[JH]
WATERCOOLING!
All you have to do is drag the hose from the back garden,
drill a massive hole in the side then put the hose though it and then turn the hose on full
Or your could visit here :D
