Kornowski
I've heard that turning on PECI can lower your temps, what is this and is it true?
I don't seem to be able to remove the other side of my case, the side behind the MOBO, could it be rivited in, it has two screws on the back like the windowed side, but it doesn't come off, it even had a hand type groove to push on?
Another thing, I'm thinking of sticking a 120mm fan on my AC 7 Pro using cable ties, think it'll make a difference over the 92mm on at the moment?
Thanks
Thanks
