More Power or Cable Management?
Ramodkk
Hey guys, I want to get a new power supply because I don't feel 100% comfortable with this power supply (500W). Now, I want to get the best bang for the buck. The scenario is;
Let's say you need 550W to power up your whole system. Would you rather get a ~600W modular PSU or a +700W non-modular PSU? Supposing both cost the same.
Thanks Danny :)
Yep that HX series from Corsair really seems very good but I think they're a bit overpriced. Here are the ones I am looking at, 2 are modular and the other 2 are not.
Corsair:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
COOLER MASTER:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171023
Antec:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371010
XIGMATEK: (surprisingly good)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817815002
They all have excellent reviews, any comments, preferences or other options??
THanks! :D
Modular FTW! I desperately need a new PSU solely for c-m purposes. It seems all the nice modular ones are way-overkill for my power needs, though. When I buy it will either be modular or have very long cables that I can run wherever I want.
Well... Most of the times you pick a PSU on how much your rig will use when idling or being under load. In general I pick the average 50% load usage. And most times a PSU will be most efficient between 40% of it's total capacity and 60% of it's capacity (give or take a few %'s).
And don't really mind Modular or not, I'm taking a closed case anyway. But even with cases such as the Nine Hundred there is this nice panel in the back where you can do some cable organization and I am quite sure you can hide unused cables back there as well :)
