Ace1627 said:Thermaltake BigWater 12cm liquid cooling system is the best, have recieved the best reviews all the places I have read. Only problem is that I cannot find it anywhere. Well that is not that informative. Thermaltake makes another very good cooling system, aquarius II and III. Hope this helps.
1. Depends on if you want it loudi mean is there any fan that can touch the cooling to sound power of a watercooled pc?
Badass heatpipes will worki don't think you can get a HSF that will match a good qualitykit/any kind of good custom kit.
