? on water cooling a P4
mike11d11
wondering if any knows what kind and where i can get a good water cooling device for my p4 3.2 prescott processor. cant keep the cpu cool enough with my heatsink. maybe around $100?
Praetor
Administrator
do you think that aquarius II is compatible with that case?
Not according to Tt it isnt :) I believe the Xaser cases are the only ones "deemed compatible" although it might just be a bunch of marketing hocus. Ive not done watercooling (only FA, FA+Peltier and Vapor) so i dunno
mike11d11
what about those electic peltiers, do think one of those could do the job in cooling the cpu. i've been seeing those around, saw one on ebay today for $75!
Praetor
Administrator
Everything you can think of for water cooling
I wouldnt quite say eeeeeeeeverything :p
Peltiers are cool but unless you've got a super ultra beast fan on the other side of it you'll want to hook up a water or vapor unit otherwise it'll burn itself out heehee
kb1ghc
i like frozenCPU.com's selection of watercooling stuff, but if i had enough money, i would watercool EVERYTHING! every tiny component
Praetor
Administrator
Why watercool if money isnt a concern? Watercooling, while much more effective than forced air cooling isnt that effective. If money's not an issue, vapor phase is the way to go
