Power Supply suggestions for GTX 570?
VpS_Serenity
Hey, I'm considering to buy a Nvidia GeForce GTX 570, but my power supply seems to be at 300W, so I was wondering if anyone could suggest/recommend a power supply?
I was thinking of a 600W or something alike for the GTX 570.
You could pass with a decent 600w. I would look for a 600-700w power supply from Corsair, antec, silverstone, seasonic, pc power and cooling, or xfx.
The seasonic is a good deal. But like I said in your other thread, measure the inside of your case and make sure a GTX 570 will fit.
Could you explain me what difference it makes to pick the seasonic out of the corsair for example?
This might be a stupid question, but does it have all the necessary cables ><?
The Seasonic is a higher quality power supply. The Corsair CX is a lowerend line of Corsair. Corsair TX/HX and AX are higherend Corsair units. Yes it will have all the cables you need.
The corsair has 40 amps on the 12V rail. The Seasonic has almost 50 amps on the 12V. They are the same price other then the rebate on the Corsair. Which you would probably get three months from now, lol.
Yeah, the Corsair CX is the low-end, but I wouldent put the TX/HX at the top with the AX. I would say its more like...CX=low-end, TX=mid-low, HX=mid-high, and AX=top of the line.
i mean, what difference would it make for me, if i have a 600w corsair or seasonic 620w, if u understand what i mean?
Like what was said earlier, better build quality. Which means it will perform better in all aspects,stess,heat,noise,life expectancy,and performance.
