Praetor's "Jiggy" technique for power supply?
Greg J.
Praetor's "Jury-rig" technique for power supply?
What can I use to prop up this power supply I ordered that is smaller than the power supply support rails? (a little over 1/4 an inch) ? Praetor, since I got 1 screw on tight, how do I use your suggested technique? :D
Praetor
Administrator
Dude... what's the related thread?! :confused:
Right off the top of my head, drill two/four holes in the case and use pencils/bolts to prop of the rest.
Greg J.
I drilled holes to use screw holes in PSU GOT IT
I got it tight. Now it hovers from the bottom rails and is stuck to the back of the case. :D Cool case mod huh? :p
Praetor
Administrator
I got it tight. Now it hovers from the bottom rails and is stuck to the back of the case. Cool case mod huh?
Glad you got it secure -- you sure enough to shake the case? :p
Greg J.
Turned upside down, everything's tight and good !
Yes, my common sense is increasing !! Soon I'll be able to go Super Saiyan comp builder ! :p :)
