gillmanjr
Hello all, a problem has starting popping up with my PC that I'm not sure what to do about. I've done google searches about this problem and found a few different things but I'm just not sure where to start. First of all my build:
ASRock Z97 1150 mobo
i5-4670k w/Zalman heatsink
MSI Radeon R9 390 8GB
Corsair RM850 PSU
Samsung 250GB SSD + 500GB WD Velociraptor + 1TB Seagate HDD
27" Dell 1440p monitor
This build is not that old, about 1 year, and I've never overclocked it, I don't run it hard. I don't even game all that often.
Now, the issue:
I have my computer set to go into sleep mode after 30 minutes or so and my Dell monitor also goes to sleep. A few weeks ago I moved the mouse and windows started back up but the monitor didn't. So I shut down the monitor and restarted it and it started. Then a few days after that the same thing happened but this time I COULD NOT get the monitor to wake back up. Windows was clearly running but the monitor would not. So I shut everything down, unplugged everything, and reset my BIOS via the jumper on the MOBO. This fixed the problem. That was about a week ago and haven't had any other issues since today.
Today I bought and downloaded the new Tomb Raider game on Steam and went to play it, as soon as the game booted the monitor went to sleep and I couldn't get it to wake up. This time I just restarted the computer. The monitor came on for the ASRock screen, then when windows booted up it went back asleep! I rebooted several times and the same thing kept happening...monitor would fall asleep right after the Windows boot screen. I was able to start and run the computer in Safe mode without problems, even with the screen resolution at 1440p.
I am kind of stumped here. The #1 cause that I see when I do a Google search is the PSU...either it being inadequate for the system (which I think you'll agree is not the problem in my case) or because it is going bad, which I find hard to believe but I suppose its possible. Could my R9 390 be crapping out? My monitor? By the way my drivers are all up to date.
Any help would be appreciated! Thanks
Corsair RM850 PSU
Now, the issue:
