Deathrow
Hey, I had a 2mb connection on aol and then they decided to upgrade it free of charge to 8mb. However since then I have had a few problems.
1/ My connection randomly disconnects (the green arrows go yellow on the desktop)
2/ My connection speed randomly increases and decreases drastically eg 5mb to 7mb then to 6mb then to 7mb and back to 5mb
3/ My web cam has stopped working (insufficient bandwidth resources on the usb it says)
4/ My game Guild Wars no longer works. Error 058 (a routing problem according to guildwars.net
So I rang aol and they said.....
1/ Try a different filter (did not work)
2/ Connect your phone line to the master phone socket using a line less than 10 metres. (Well I cant connect it to the line using a cable less than 10 metres)
- therefore the only solution I can find is to buy a wireless modem and put it on the master socket. But how will this affect things?
Thank you, Scott.
Thank you, Scott.
