I am currently running a Dell Wireless 1450 Wireless USB Adapter. Says its high speed certified, wi fi certified and cisco compatible (this is all written on the back of it, not sure what it all means, just putting as much info as I can. The router currently used in our house hold is a D-Link 802.11g/2.4 GHz. Every so often the conenction will drop, or I get really poor connection. Just curious if you could tell me if it is my wireless adapter, or if the router is a cheap one. Would also like to know of a good setup to get good connection and speeds all the time.( Change to a different adapter? new router? or maybe both?) Thanks A Lot.
I have read on here that the PCI router card,adapters(dont know correct term) are better for siganl then the one that I would have received from dell, which is a USB style. (also what is the difference between wireless G and Wireless N, been looking at the Linksys stuff, also does the wireless adapter have to match the "G" or "N"
I have also read alot of good things about Linksys, which setup would be good for me, need a good strong signal.
