gamerwithoutrig
Can I have 4 x 2 GB DDR3 and GTX 470 1280 MB sli on the Gigabyte GA-X58A-UD3R?? XD
Yes, though don't get 4x2GB of RAM on an X58 board, it's designed for triple channel RAM (3x2GB)
You can, but you'd be better off with 3x2GB since it will run in tri channel.
you wouldn't want 4x2GB anyway. 2x4GB is a much better configuration since it leaves room to upgrade.
If you need more than 6Gb, you could always go 3x4GB.
Ok, I'll go for this: Kingston ValueR. DDR3 1333MHz 8GB, CL9 Kit w/2x ValueRAM 4GB DDR3
Don't use 2 sticks on an X58 board as already explained, it will only run in Single Channel mode.
Use 3 sticks.
You just need to search for 6GB DDR3 on newegg and find a set that has 1600mhz somewhere in the listing name. You will want triple channel with an X58 board
Hmm okay. i don't know many good sites in that area of he world, maybe some more local can help you
But, I dont have that option
