Does Ram speed matter?
bm23
Is there a noticeable difference in ram speed, say. 1600 vs 1866 or 1333 vs 1600, assuming no OC?
Between 1333 and 1600, I would say there is a difference, depending on your timings on the RAM, too. Between 1600 and 1866, I don't think many boards or processors use the extra speed all that well. Getting 1600 RAM with good timings is the best bet, in my opinion. (Better timings = lower. 8-8-8-24 is better than 9-10-9-27)
Technically, there's a difference between them all. Timings don't make that much difference anymore, most new CPUs are able to hide latency better and a 10 cycle CAS delay isn't exactly that long when you have 667000000 cycles available.
That said, overall, I'd say you likely wouldn't notice the difference unless you ran benchmarks.
Thanks for the replies guys :good: I was gona get 8gb of 1866, instead of 1600 since the price difference isn't a lot but since there's no noticeable difference in performance, no point wasting those 15 bucks then :D
