Thanatos
So here's the problem.
I'm trying to set up a minecraft server. I have a Linksys WRT52GS V7.2. And I absolutely CANNOT open port 25565!!!!!
So I go into my router's setup page and go to the 'Applications and Gaming' tab and enter this into one of the blank spaces:
This should work, right? Did I miss a step? Is that IP address correct? Because every time I try to test the port the website I'm using (http://www.yougetsignal.com/tools/open-ports/) it tells me that the port is closed using my current IP.
Here's a screenshot of CMD with the 'ipconfig' command, if that would help you out at all:
Ive also gone into the windows firewall settings and entered these exceptions:
Does anyone have any ideas? please help me out.
