multi-tasker-X
Hello everybody! I'm here for advice on a new computer. I have really only had 2 desktops.
My first one was rebuilt computer back in 1999 it cost me 2000$ .
My second one was an old used computer i picked up for a cheap 200$.(which i'm currently using)
Now my third computer i finally saved up some cash to build my own. I have never built my own computer but i heard it's not so hard. This is what i have in mind so far.
Note: I mostly do a lot of multitasking and video editing. Sometimes i play steam & play emulator games, but having the best graphics is not important for me. This is why im keeping my current video card in my new build.
My Current Build:
Windows7 64bit
Intel Core 2 Quad CPU Q8200
Ram: 8GB
Hard Drives: 500GB & 500GB
http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148135
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
Video Card: Navida GeForce GT 640 DDR3, 2 GB ram
http://www.newegg.ca/Product/Product.aspx?Item=N82E16814125433&_ga=1.122684811.1408014851.1455240736
My New Build:
This is what i am thinking.
Processor: Intel Core i7-5820K Haswell-E 6-Core 3.3 GHz
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819117402&_ga=1.94727452.1408014851.1455240736
Motherboard: MSI X99A SLI PLUS LGA 2011-v3 Intel X99
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130841&_ga=1.94727452.1408014851.1455240736
Ram: G.SKILL Ripjaws 4 Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4 19200)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231796&_ga=1.94727452.1408014851.1455240736
Hard Drives: Not buying new ones, Use my current 2 hard drives 2 x 500GB
Video Card: Not buying a new one, Use my current video card.(Navida GeForce GT 640)
More:
I was looking online and it said i could get a combo(the same above) except with an SSD drive.
Hard Drive: Crucial BX200 2.5" 480GB SATA III Internal Solid State Drive (SSD)
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820156067&_ga=1.94727452.1408014851.1455240736
So my questions are:
#1 Do i really need an SSD Drive? I was planning on using my current 2 hard drives, just transferring them over.
#2 If i do get an SSD drive, should i get 2?
I've always had 2 hard drives, that way i keep all my important things on the second hard drive and if i need to reformat my computer, i can easily do it without spending hours transfering things. Im worried that if i partition 1 drive, then i can't easily reformat it. This is why i've always had 2 hard drives,
#3 or.. Can i use the 1 SSD Drive as my main drive and the other 2 hard drives as my backups, to store things. Will it be complicated to setup?
#4 What other things do i need?
I already have a case from my soon to be old computer,
I already have power supply, it's an 800w
am i missing anything else?
#5 How do you guys like my setup?
any advice? thanks!
My Current Build:
Windows7 64bit
Ram: 8GB
My New Build:
More:
any advice? thanks!
