arnel222429
one of my PC is overheating...i suspected its a power supply failure...i bought a brand new one which is 650W, then i try it to Turn-on after 15 min still the same...what's the problem in here!? please help techpeople.
Can you run software to record temps of your video card and proccesor?
Which psu model did you buy?one of my PC is overheating...i suspected its a power supply failure...i bought a brand new one which is 650W, then i try it to Turn-on after 15 min still the same...what's the problem in here!? please help techpeople.
there's probably something out there....
Have you cleaned it lately?
ok the other advice was to run a program to show ur cpu temp and GPU temp and let us know
its the CPU...
When i by mistakely never put my HSF on properly, the comp switched off within 2 minutes....
