atthedouble2
I've got a bit of a problem with the speed of my CPU fan.
I'm using ASUS Q-Fan to control it at the moment.
If I turn Q-Fan off, then the fan zooms off like a rocket to 2800rpm, which is pretty loud!
If I turn Q-Fan onto performance mode, which is supposed to be the highest setting, then the fan slows down to only 1000rpm, and I want it to run at about 1600.
I've tried playing with Q-Fan, and you cant enter an RPM manually.
I've also tried speedfan, but I don't think my motherboard is supported because it wont work - I've followed guides - still nothing.
Any software you people know of that can control the speed of the fan?
Thanks
Thanks
