My first build, does it work?
Bobo
banned
Not a huge difference. Not enough to justify taking $20 away from another part of his computer.
joeswm8
8 more pixel processors(= much better performance), a lot more future proof, and great OC ability
thats worth 20 bucks any day, versus replaceing it half as soon
Max Camino
Alright, after this discussion, here is what i came up with. I went for some cheaper things because the mail in rebates went away. A final check to make sure everything looks ok.
Mobo http://www.newegg.com/Product/Product.asp?Item=N82E16813128015
Processor: http://www.newegg.com/Product/Product.asp?Item=N82E16819115005
RAM: http://www.newegg.com/Product/Product.asp?Item=N82E16820145566
HDD: http://www.newegg.com/Product/Product.asp?Item=N82E16822144701
Vid Card: http://www.newegg.com/Product/Product.asp?Item=N82E16814130062
Power Supply: http://www.newegg.com/Product/Product.asp?Item=N82E16817152026
Case:http://www.newegg.com/Product/Product.asp?Item=N82E16811144102
Mouse/Keyboard: http://www.newegg.com/Product/Product.asp?Item=N82E16823126017
Same monitor, and i havent decided on a CD/DVD drive.
I changed the power to a cheaper one and i just wanted to make sure that it worked still. And that everything else works.
Max Camino
Well, first, this was fun figuring one out myself. This way i have better knowledge of what im getting because i looked for everything and did it myself. Now i also know more about this stuff, and ill look at your build and see if maybe i want it more.
Thanks for the help either way though.
Bobo
banned
That's not bad for an included PSU, but you would still be a lot better off to go with the Xclio or something similar.
Max Camino
I have a DVD player on a TV so no DVDs, but this cant burn anything? It says on the info page that it can burn CDs i think.
