Hi all, I've got a Dell 2007 monitor (A02) running on a nVidia 6800 vanilla (dell's card), DVI,using driver version 7.7.7.4. It's being used on an XPS 400, Pent. D 930, 3.0G, 2G RAM, Windows XP, sp2.
Using standard XP screen savers the monitor will sometimes freeze as soon as the screen saver begins. I get a black screen for about 1 second, then it displays a horrible horizontal line pattern, each line about 1/2 inch long and a pxels width wide, on a slight angle all over the screen. Of course, I can do nothing because I can't see a cursor or any icons. No monitor controls have any effect on the problem and I am forced to reboot using the pc power button. This obviously poses problems when I'm in a program and haven't saved work, etc., so I'm pretty bummed about having to turn off the pc this way. It does fix itself with the reboot, though.
Sooo, I tried many different drivers for the card, and none but this (that I can find) support this monitor's res. and aspect ratio.
Monitor is only two months old, but like I said I think it has to do with the screen savers. Or maybe not---I really don't know.
Anyone have any ideas for a fix on this? It's about to drive me to drink . . .
Thanks,
Jeff
Thanks,
Jeff
