Zlob AdWare/Trojan!?
PurePwnage
Hi,
I was just kinda surfing the internet and went down to my desktop when I noticed a couple odd icons for pornography. I immediately deleted them, emptied my trash bin, and then one more came up.
I got a Windows Alert telling me what this does and it said it'll make porn pop ups and stuff.
I immediately shut down.
Does anybody have any help for me?
PS: I have McAfee.
PPS: I 100% do not look at porn, but I do use torrents...so maybe it could have been in one of those.
I went into Safe Mode. I turned off System Restore. I followed these steps:
http://www.symantec.com/security_response/writeup.jsp?docid=2005-060712-1407-99&tabid=3 said:
1. Click Start > Run.
2. Type regedit
3. Click OK.
Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
4. Navigate to the subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
5. In the right pane, delete the value:
"RegSvr32" = "%System%\msmsgs.exe"
6. Navigate to the subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
7. In the right pane, reset the value:
"Shell" = "Explorer.exe, msmsgs.exe"
to:
"Shell" = "Explorer.exe"
8. Navigate to the subkey:
\policies\explorer\run
9. In the right pane, delete the value:
"notepad.exe" = "msmsgs.exe"
10. Navigate to the subkey:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion
11. In the right pane, delete the value:
"uuid" = "86c29b2f-3389-418b-9b47-c2b09b6abc07"
12. Exit the Registry Editor.
But none of the stuff htey told me to do was there. It was already deleted/changed (Step 7 was already Explorer.exe).
Do you think I may have gotten rid of it already?
well, this seems familiar to me... I had such trouble before, but not popups. Many of the images on websites (including google image search) were changed to an ad that my pc is infected and clicking it would force me to download an "antivirus".
I removed kaspersky (the antivirus i was using then) and installed AVG and..guess what? I had a virus: Win32.Heur . I quickly scanned my entire hard drive and removed few files (I still get an error message at startup that "scss.exe" i think is missing, so it won't be easy to forget).
Try to get one of the top antivirus software, like AVG or Kaspersky, and run a full scan of your computer.
I'm getting BSOD when I do a normal boot (after a minute or so of doing the startup programs). Should I do Safe w/ Networking?
Scan saved at 4:08:55 PM, on 8/5/2008
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16674)
Boot mode: Safe mode with network support
Running processes:
C:\WINDOWS\system32\csrss.exe
C:\WINDOWS\system32\savedump.exe
C:\WINDOWS\system32\lsass.exe
C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
C:\Program Files\McAfee\MPF\MPFSrv.exe
C:\WINDOWS\system32\userinit.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\System32\wbem\wmiprvse.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.daemon-search.com/startpage
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
F3 - REG:win.ini: run="C:\WINDOWS\system32\winupdate.exe"
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: flashget urlcatch - {2F364306-AA45-47B5-9F9D-39A8B94E7EF7} - C:\Program Files\FlashGet\jccatch.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: scriptproxy - {7DB2D5A0-7241-4E79-B68D-6309F01C5231} - C:\Program Files\McAfee\VirusScan\scriptsn.dll
O2 - BHO: FlashGet GetFlash Class - {F156768E-81EF-470C-9057-481BA8380DBA} - C:\Program Files\FlashGet\getflash.dll
O4 - HKLM\..\Run: [SkyTel] SkyTel.EXE
O4 - HKLM\..\Run: [RTHDCPL] RTHDCPL.EXE
O4 - HKLM\..\Run: [Alcmtr] ALCMTR.EXE
O4 - HKLM\..\Run: [HPDJ Taskbar Utility] C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe
O4 - HKLM\..\Run: [HPHmon04] C:\WINDOWS\system32\hphmon04.exe
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [amd_dc_opt] C:\Program Files\AMD\Dual-Core Optimizer\amd_dc_opt.exe
O4 - HKLM\..\Run: [Start WingMan Profiler] C:\Program Files\Logitech\Gaming Software\LWEMon.exe /noui
O4 - HKLM\..\Run: [mcagent_exe] C:\Program Files\McAfee.com\Agent\mcagent.exe /runkey
O4 - HKLM\..\Run: [AppleSyncNotifier] C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\QTTask.exe" -atboottime
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [lsass driver] C:\WINDOWS\msauc.exe
O4 - HKLM\..\Run: [KernelFaultCheck] %systemroot%\system32\dumprep 0 -k
O4 - HKCU\..\Run: [WhatPulse] C:\Program Files\WhatPulse\WhatPulse.exe
O4 - HKCU\..\Run: [Aim6] "C:\Program Files\AIM6\aim6.exe" /d locale=en-US ee://aol/imApp
O4 - HKCU\..\Run: [DAEMON Tools Lite] "C:\Program Files\DAEMON Tools Lite\daemon.exe" -autorun
O4 - HKCU\..\Run: [SVCHOST.EXE] C:\WINDOWS\system32\drivers\svchost.exe
O4 - HKCU\..\Run: [iexplorer] C:\WINDOWS\iexplorer.exe --system
O4 - Startup: Adobe Gamma.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: GN-WP01GS Utility.lnk = C:\Program Files\Gigabyte\Gigabyte WP01GS Wireless PCI Adapter SoftAP\Installer\WINXP\RaUI.exe
O4 - Global Startup: UltraMon.lnk = ?
O8 - Extra context menu item: &Download All with FlashGet - C:\Program Files\FlashGet\jc_all.htm
O8 - Extra context menu item: &Download with FlashGet - C:\Program Files\FlashGet\jc_link.htm
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~1\MICROS~2\OFFICE11\EXCEL.EXE/3000
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: AIM - {AC9E2541-2814-11d5-BC6D-00B0D0A1DE45} - C:\Program Files\AIM\aim.exe (file missing)
O9 - Extra button: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\Program Files\FlashGet\FlashGet.exe
O9 - Extra 'Tools' menuitem: FlashGet - {D6E814A0-E0C5-11d4-8D29-0050BA6940E3} - C:\Program Files\FlashGet\FlashGet.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O16 - DPF: {11260943-421B-11D0-8EAC-0000C07D88CF} (iPIX ActiveX Control) - http://www.ipix.com/download/ipixx.cab
O16 - DPF: {17492023-C23A-453E-A040-C7C580BBF700} (Windows Genuine Advantage Validation Tool) - http://go.microsoft.com/fwlink/?linkid=39204
O16 - DPF: {30528230-99f7-4bb4-88d8-fa1d4f56a2ab} (Installation Support) - C:\Program Files\Yahoo!\Common\Yinsthelper.dll
O17 - HKLM\System\CCS\Services\Tcpip\..\{D007E548-1E09-481A-A51B-02ADD57D3E35}: NameServer = 68.87.71.226,68.87.73.242
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Apache2.2 - Apache Software Foundation - C:\Xampp\apache\bin\apache.exe
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleMobileDeviceService.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\1050\Intel 32\IDriverT.exe
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LiveUpdate - Symantec Corporation - C:\PROGRA~1\Symantec\LIVEUP~1\LUCOMS~1.EXE
O23 - Service: McAfee Services (mcmscsvc) - McAfee, Inc. - C:\PROGRA~1\McAfee\MSC\mcmscsvc.exe
O23 - Service: McAfee Network Agent (McNASvc) - McAfee, Inc. - c:\program files\common files\mcafee\mna\mcnasvc.exe
O23 - Service: McAfee Scanner (McODS) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcods.exe
O23 - Service: McAfee Proxy Service (McProxy) - McAfee, Inc. - c:\PROGRA~1\COMMON~1\mcafee\mcproxy\mcproxy.exe
O23 - Service: McAfee Real-time Scanner (McShield) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcshield.exe
O23 - Service: McAfee SystemGuards (McSysmon) - McAfee, Inc. - C:\PROGRA~1\McAfee\VIRUSS~1\mcsysmon.exe
O23 - Service: McAfee Personal Firewall Service (MpfService) - McAfee, Inc. - C:\Program Files\McAfee\MPF\MPFSrv.exe
O23 - Service: mysql - Unknown owner - c:\Xampp\mysql\bin\mysqld-nt.exe
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: Pml Driver HPH11 - HP - C:\WINDOWS\system32\HPHipm11.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: TuneUp Drive Defrag Service (TuneUp.Defrag) - TuneUp Software GmbH - C:\WINDOWS\System32\TuneUpDefragService.exe
O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe
O24 - Desktop Component 0: (no name) - http://www.protrade.com/
O24 - Desktop Component 2: (no name) - http://moola.com/
End of file - 8548 bytes
Malwarebytes' Anti-Malware 1.24
Database version: 1012
Windows 5.1.2600 Service Pack 3
4:21:58 PM 8/5/2008
mbam-log-8-5-2008 (16-21-58).txt
Scan type: Quick Scan
Objects scanned: 41573
Time elapsed: 3 minute(s), 4 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 3
Registry Data Items Infected: 3
Folders Infected: 0
Files Infected: 13
(No malicious items detected)
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\svchost.exe (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\iexplorer (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\lsass driver (Trojan.Agent) -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Userinit (Trojan.Agent) -> Data: c:\windows\system32\userinit.exe -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\System (Rootkit.DNSChanger) -> Data: kduxh.exe -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows\Run (Trojan.Downloader) -> Data: c:\windows\system32\winupdate.exe -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
C:\WINDOWS\system32\kduxh.exe (Rootkit.DNSChanger) -> Delete on reboot.
C:\WINDOWS\system32\wpx11.cpx (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\sex1.ico (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\sex2.ico (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\sex3.ico (Malware.Trace) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\drivers\svchost.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\iexplorer.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\msauc.exe (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wpx12.cpx (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\ntload.dll (Trojan.Agent) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\winupdate.exe (Trojan.Downloader) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\wscmp.dll (Adware.BHO) -> Quarantined and deleted successfully.
C:\WINDOWS\system32\lich.dat (Stolen.Data) -> Delete on reboot.
I believe those were the only two.
OK Purepwnage, can you pls do the following:
1. - Pls remove viewpoint manager: Control Panel > Add / Remove Programs > Remove Viewpoint manger.
2. - Hello,
Download and Run ComboFix
If you already have Combofix, please delete this copy and download it again as it's being updated regularly.
Note: Do not mouseclick combofix's window whilst it's running. That may cause it to stall
Combofix should never take more that 20 minutes including the reboot if malware is detected.
If it does, open Task Manager then Processes tab (press ctrl, alt and del at the same time) and end any processes of findstr, find, sed or swreg, then combofix should continue.
If that happened we want to know, and also what process you had to end.
In your reply:
  • Post the combo fix log
  • Post a Fresh Hijackthis log
Thankyou
I deleted Viewpoint MP and Manager earlier today.
As requested...
combofix said:
ComboFix 08-08-04.09 - Mike 2008-08-05 23:12:20.1 - NTFSx86 NETWORK
Microsoft Windows XP Professional 5.1.2600.3.1252.1.1033.18.1666 [GMT -4:00]
Running from: C:\Documents and Settings\Mike\Desktop\ComboFix.exe
WARNING -THIS MACHINE DOES NOT HAVE THE RECOVERY CONSOLE INSTALLED !!
((((((((((((((((((((((((((((((((((((((( Other Deletions )))))))))))))))))))))))))))))))))))))))))))))))))
C:\Documents and Settings\Mike\Application Data\macromedia\Flash Player\#SharedObjects\MRCB85P5\interclick.com
C:\Documents and Settings\Mike\Application Data\macromedia\Flash Player\#SharedObjects\MRCB85P5\interclick.com\ud.sol
C:\Documents and Settings\Mike\Application Data\macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#interclick.com
C:\Documents and Settings\Mike\Application Data\macromedia\Flash Player\macromedia.com\support\flashplayer\sys\#interclick.com\settings.sol
C:\install.exe
C:\WINDOWS\system32\shell31.dll
C:\WINDOWS\wiaservb.log
((((((((((((((((((((((((( Files Created from 2008-07-06 to 2008-08-06 )))))))))))))))))))))))))))))))
2008-08-05 16:16 . 2008-08-05 16:16 <DIR> d-------- C:\Program Files\Malwarebytes' Anti-Malware
2008-08-05 16:16 . 2008-08-05 16:16 <DIR> d-------- C:\Documents and Settings\Mike\Application Data\Malwarebytes
2008-08-05 16:16 . 2008-08-05 16:16 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\Malwarebytes
2008-08-05 16:16 . 2008-07-30 20:07 38,472 --a------ C:\WINDOWS\system32\drivers\mbamswissarmy.sys
2008-08-05 16:16 . 2008-07-30 20:07 17,144 --a------ C:\WINDOWS\system32\drivers\mbam.sys
2008-08-05 16:08 . 2008-08-05 16:08 <DIR> d-------- C:\Program Files\Trend Micro
2008-08-05 11:50 . 2008-08-05 11:50 29 --a------ C:\WINDOWS\system32\epfforii.tmp
2008-08-05 11:49 . 2003-07-16 12:21 18,688 --a------ C:\WINDOWS\system32\drivers\cdaudio.sys
2008-08-05 11:49 . 2003-07-16 12:21 18,688 --a--c--- C:\WINDOWS\system32\dllcache\cdaudio.sys
2008-08-04 13:05 . 2008-08-04 13:14 <DIR> d-------- C:\Program Files\MVPSavReader
2008-08-04 13:05 . 1998-06-01 00:00 1,056,768 --a------ C:\WINDOWS\system32\MSJet35.dll
2008-08-04 13:05 . 1998-06-01 00:00 417,792 --a------ C:\WINDOWS\system32\MsRepl35.dll
2008-08-04 13:05 . 1998-06-01 00:00 262,144 --a------ C:\WINDOWS\system32\MSRD2x35.dll
2008-08-04 13:05 . 1998-06-01 00:00 139,264 --a------ C:\WINDOWS\system32\MSJInt35.dll
2008-08-04 13:05 . 1996-12-05 00:00 77,824 --a------ C:\WINDOWS\system32\ODBCTL32.dll
2008-08-04 13:05 . 1998-06-01 00:00 36,864 --a------ C:\WINDOWS\system32\MSJtEr35.dll
2008-07-31 11:17 . 1997-01-16 00:00 71,680 --a------ C:\WINDOWS\ST5UNST.EXE
2008-07-31 11:17 . 2008-07-31 11:17 670 --a------ C:\WINDOWS\ST5UNST.000
2008-07-30 15:31 . 2008-08-03 19:33 463 --a------ C:\WINDOWS\EAGRAPH.INI
2008-07-29 17:55 . 2008-07-29 17:55 0 --a------ C:\WINDOWS\wincmd.ini
2008-07-29 17:47 . 2008-07-29 17:47 <DIR> d-------- C:\Program Files\kraw
2008-07-28 22:12 . 2008-07-28 22:38 <DIR> d-------- C:\Program Files\HmelyoffLabs
2008-07-27 19:37 . 2004-12-10 10:06 327,680 --a------ C:\WINDOWS\system32\vp6dec.ax
2008-07-27 19:37 . 2007-04-12 15:01 118,832 --a------ C:\WINDOWS\system32\SHW32.DLL
2008-07-26 18:30 . 2008-07-26 18:31 <DIR> d-------- C:\Program Files\iTunes
2008-07-26 18:30 . 2008-07-26 18:30 <DIR> d-------- C:\Program Files\iPod
2008-07-15 19:09 . 2008-07-15 19:09 42,320 --a------ C:\WINDOWS\system32\xfcodec.dll
2008-07-11 20:33 . 2008-07-11 20:36 <DIR> d-------- C:\Xampp
2008-07-11 18:10 . 2008-07-11 18:10 <DIR> d-------- C:\Program Files\CoreFTP
2008-07-11 18:10 . 2008-07-11 18:22 <DIR> d-------- C:\Documents and Settings\Mike\Application Data\CoreFTP
2008-07-10 18:54 . 2008-07-10 18:54 <DIR> d-------- C:\Program Files\TuneUp Utilities 2008
2008-07-10 18:54 . 2008-07-10 18:54 <DIR> d-------- C:\Documents and Settings\Mike\Application Data\TuneUp Software
2008-07-10 18:54 . 2008-07-10 18:54 <DIR> d-------- C:\Documents and Settings\All Users\Application Data\TuneUp Software
2008-07-10 18:54 . 2008-07-10 18:54 307,968 --a------ C:\WINDOWS\system32\TuneUpDefragService.exe
2008-07-10 18:54 . 2008-02-27 13:15 28,416 --a------ C:\WINDOWS\system32\uxtuneup.dll
2008-07-10 18:53 . 2008-07-10 18:53 <DIR> d-------- C:\Program Files\Common Files\Wise Installation Wizard
2008-07-10 18:39 . 2008-07-10 18:55 <DIR> d-------- C:\WINDOWS\system32\NtmsData
2008-07-10 14:53 . 2008-07-10 14:53 <DIR> d-------- C:\Program Files\ffdshow
2008-07-10 14:53 . 2008-06-22 20:33 60,273 --a------ C:\WINDOWS\system32\pthreadGC2.dll
2008-07-10 14:53 . 2008-06-22 20:33 7,680 --a------ C:\WINDOWS\system32\ff_vfw.dll
2008-07-10 14:53 . 2008-06-22 20:33 547 --a------ C:\WINDOWS\system32\ff_vfw.dll.manifest
(((((((((((((((((((((((((((((((((((((((( Find3M Report ))))))))))))))))))))))))))))))))))))))))))))))))))))
2008-08-05 20:15 --------- d-----w C:\Program Files\Viewpoint
2008-08-05 20:15 --------- d-----w C:\Documents and Settings\Mike\Application Data\Viewpoint
2008-08-05 20:15 --------- d-----w C:\Documents and Settings\All Users\Application Data\Viewpoint
2008-08-05 16:28 --------- d-s---w C:\Program Files\Xfire
2008-08-05 15:58 --------- d-----w C:\Documents and Settings\Mike\Application Data\uTorrent
2008-08-05 15:49 33,056 ----a-w C:\WINDOWS\system32\userinit.exe
2008-07-28 00:00 --------- d-----w C:\Program Files\Common Files\EasyInfo
2008-07-27 23:56 --------- d-----w C:\Program Files\EA SPORTS
2008-07-27 23:49 107,888 ----a-w C:\WINDOWS\system32\CmdLineExt.dll
2008-07-27 23:37 --------- d--h--w C:\Program Files\InstallShield Installation Information
2008-07-26 22:30 --------- d-----w C:\Program Files\Bonjour
2008-07-21 22:22 --------- d-----w C:\Documents and Settings\Mike\Application Data\Xfire
2008-07-15 22:09 22,328 ----a-w C:\WINDOWS\system32\drivers\PnkBstrK.sys
2008-07-15 22:08 107,832 ----a-w C:\WINDOWS\system32\PnkBstrB.exe
2008-07-07 12:03 --------- d-----w C:\Program Files\McAfee
2008-07-05 19:29 --------- d-----w C:\Documents and Settings\Mike\Application Data\Hamachi
2008-07-05 19:24 25,280 ----a-w C:\WINDOWS\system32\drivers\hamachi.sys
2008-07-04 02:51 --------- d-----w C:\Documents and Settings\Guest\Application Data\Realtime Soft
2008-07-03 16:47 --------- d-----w C:\Program Files\QuickTime
2008-07-03 16:44 --------- d-----w C:\Program Files\Common Files\Apple
2008-07-03 16:41 --------- d-----w C:\Program Files\Apple Software Update
2008-07-01 00:54 --------- d-----w C:\Program Files\Common Files\McAfee
2008-06-20 07:06 --------- d-----w C:\Program Files\FlashGet
2008-06-15 15:12 --------- d-----w C:\Program Files\UltraMon
2008-06-15 15:12 --------- d-----w C:\Program Files\Common Files\Realtime Soft
2008-06-15 15:12 --------- d-----w C:\Documents and Settings\Mike\Application Data\Realtime Soft
2008-06-15 15:12 --------- d-----w C:\Documents and Settings\All Users\Application Data\Realtime Soft
2008-06-13 11:05 272,128 ------w C:\WINDOWS\system32\drivers\bthport.sys
2008-05-07 05:12 1,288,192 ----a-w C:\WINDOWS\system32\quartz.dll
2007-12-11 22:01 22,328 ----a-w C:\Documents and Settings\Mike\Application Data\PnkBstrK.sys
((((((((((((((((((((((((((((((((((((( Reg Loading Points ))))))))))))))))))))))))))))))))))))))))))))))))))
*Note* empty entries & legit default entries are not shown
REGEDIT4
[HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"WhatPulse"="C:\Program Files\WhatPulse\WhatPulse.exe" [2006-08-21 13:48 665600]
"ctfmon.exe"="C:\WINDOWS\system32\ctfmon.exe" [2008-04-13 20:12 15360]
"Aim6"="C:\Program Files\AIM6\aim6.exe" [2008-01-03 12:15 50528]
"DAEMON Tools Lite"="C:\Program Files\DAEMON Tools Lite\daemon.exe" [2008-04-01 05:39 486856]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"HPDJ Taskbar Utility"="C:\WINDOWS\system32\spool\drivers\w32x86\3\hpztsb07.exe" [2006-01-06 15:07 188416]
"HPHmon04"="C:\WINDOWS\system32\hphmon04.exe" [2006-01-06 15:07 348160]
"NvCplDaemon"="C:\WINDOWS\system32\NvCpl.dll" [2006-07-12 01:19 7626752]
"NvMediaCenter"="C:\WINDOWS\system32\NvMcTray.dll" [2006-07-12 01:19 86016]
"amd_dc_opt"="C:\Program Files\AMD\Dual-Core Optimizer\amd_dc_opt.exe" [2006-11-17 16:49 77824]
"Start WingMan Profiler"="C:\Program Files\Logitech\Gaming Software\LWEMon.exe" [2008-04-04 11:38 88584]
"mcagent_exe"="C:\Program Files\McAfee.com\Agent\mcagent.exe" [2007-01-05 17:21 566872]
"AppleSyncNotifier"="C:\Program Files\Common Files\Apple\Mobile Device Support\bin\AppleSyncNotifier.exe" [2008-07-10 09:47 116040]
"QuickTime Task"="C:\Program Files\QuickTime\QTTask.exe" [2008-05-27 10:50 413696]
"iTunesHelper"="C:\Program Files\iTunes\iTunesHelper.exe" [2008-07-10 10:51 289064]
"Malwarebytes Anti-Malware (reboot)"="C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" [2008-07-30 20:07 1187448]
"SkyTel"="SkyTel.EXE" [2006-05-16 06:04 2879488 C:\WINDOWS\SkyTel.exe]
"RTHDCPL"="RTHDCPL.EXE" [2006-08-14 02:00 16050176 C:\WINDOWS\RTHDCPL.EXE]
"nwiz"="nwiz.exe" [2006-07-12 01:19 1519616 C:\WINDOWS\system32\nwiz.exe]
C:\Documents and Settings\Mike\Start Menu\Programs\Startup\
Adobe Gamma.lnk - C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe [2005-03-16 20:16:50 113664]
C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
GN-WP01GS Utility.lnk - C:\Program Files\Gigabyte\Gigabyte WP01GS Wireless PCI Adapter SoftAP\Installer\WINXP\RaUI.exe [2007-08-06 13:32:20 720896]
UltraMon.lnk - C:\WINDOWS\Installer\{AF0FA6D7-96F3-468A-ABB7-28BE006EA8E9}\IcoUltraMon.ico [2008-06-15 11:12:37 29310]
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\winlogon]
"UIHost"="C:\\WINDOWS\\system32\\logonuiX.exe"
[HKEY_LOCAL_MACHINE\software\microsoft\windows nt\currentversion\drivers32]
"VIDC.XFR1"= xfcodec.dll
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\Wdf01000.sys]
@="Driver"
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Aim6]
--a------ 2008-01-03 12:15 50528 C:\Program Files\AIM6\aim6.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Flashget]
--a------ 2007-09-25 04:10 2007088 C:\Program Files\FlashGet\flashget.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\iTunesHelper]
--a------ 2008-07-10 10:51 289064 C:\Program Files\iTunes\iTunesHelper.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\QuickTime Task]
--a------ 2008-05-27 10:50 413696 C:\Program Files\QuickTime\QTTask.exe
[HKEY_LOCAL_MACHINE\software\microsoft\shared tools\msconfig\startupreg\Zune Launcher]
--a------ 2008-04-29 19:56 158624 c:\Program Files\Zune\ZuneLauncher.exe
[HKEY_CURRENT_USER\software\microsoft\windows\currentversion\run-]
"DAEMON Tools Lite"="C:\Program Files\DAEMON Tools Lite\daemon.exe" -autorun
[HKEY_LOCAL_MACHINE\software\microsoft\windows\currentversion\run-]
"SunJavaUpdateSched"="C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"
"QuickTime Task"="C:\Program Files\QuickTime\QTTask.exe" -atboottime
[HKEY_LOCAL_MACHINE\software\microsoft\security center]
"AntiVirusOverride"=dword:00000001
[HKEY_LOCAL_MACHINE\software\microsoft\security center\Monitoring\McAfeeAntiVirus]
"DisableMonitoring"=dword:00000001
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile]
"EnableFirewall"= 0 (0x0)
[HKLM\~\services\sharedaccess\parameters\firewallpolicy\standardprofile\AuthorizedApplications\List]
"%windir%\\system32\\sessmgr.exe"=
"C:\\Program Files\\America's Army\\System\\ArmyOps.exe"=
"C:\\Program Files\\Common Files\\AOL\\Loader\\aolload.exe"=
"C:\\Program Files\\uTorrent\\uTorrent.exe"=
"C:\\WINDOWS\\system32\\PnkBstrA.exe"=
"C:\\WINDOWS\\system32\\PnkBstrB.exe"=
"C:\\Program Files\\AIM6\\aim6.exe"=
"C:\\Program Files\\Xfire\\xfire.exe"=
"C:\\Program Files\\SopCast\\adv\\SopAdver.exe"=
"C:\\Program Files\\SopCast\\SopCast.exe"=
"%windir%\\Network Diagnostic\\xpnetdiag.exe"=
"C:\\Program Files\\FlashGet\\FlashGet.exe"=
"C:\\Program Files\\Common Files\\McAfee\\MNA\\McNASvc.exe"=
"C:\\Program Files\\Bonjour\\mDNSResponder.exe"=
"C:\\Program Files\\iTunes\\iTunes.exe"=
R2 zumbus;Zune Bus Enumerator Driver;C:\WINDOWS\system32\DRIVERS\zumbus.sys [2008-04-29 19:39]
S2 Apache2.2;Apache2.2;C:\Xampp\apache\bin\apache.exe [2008-06-14 13:02]
S2 UltraMonUtility;UltraMon Utility Driver;C:\Program Files\Common Files\Realtime Soft\UltraMonMirrorDrv\x32\UltraMonUtility.sys [2006-09-24 20:22]
S2 UxTuneUp;TuneUp Theme Extension;C:\WINDOWS\System32\svchost.exe [2008-04-13 20:12]
S2 ZuneBusEnum;Zune Bus Enumerator;c:\WINDOWS\system32\ZuneBusEnum.exe [2008-04-29 19:56]
S3 LUDrv32;LUDrv32;D:\FXDrv32.sys []
S3 TuneUp.Defrag;TuneUp Drive Defrag Service;C:\WINDOWS\System32\TuneUpDefragService.exe [2008-07-10 18:54]
S3 UltraMonMirror;UltraMonMirror;C:\WINDOWS\system32\DRIVERS\UltraMonMirror.sys [2006-09-24 20:23]
S3 USBNET_XP;Instant Wireless XP USB Network Adapter ver.2.6 Driver;C:\WINDOWS\system32\DRIVERS\netusbxp.sys [2002-02-20 03:34]
S3 ZuneWlanCfgSvc;Zune Wireless Configuration Service;c:\WINDOWS\system32\ZuneWlanCfgSvc.exe [2008-04-29 19:56]
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Svchost - NetSvcs
UxTuneUp
*Newly Created Service* - CATCHME
Contents of the 'Scheduled Tasks' folder
2008-08-05 C:\WINDOWS\Tasks\1-Click Maintenance.job
- C:\Program Files\TuneUp Utilities 2008\OneClickStarter.exe [2008-02-29 14:24]
2008-07-30 C:\WINDOWS\Tasks\AppleSoftwareUpdate.job
- C:\Program Files\Apple Software Update\SoftwareUpdate.exe [2008-04-11 17:57]
2008-07-15 C:\WINDOWS\Tasks\McDefragTask.job
- c:\program files\mcafee\mqc\QcConsol.exe [2007-12-04 13:32]
2008-08-01 C:\WINDOWS\Tasks\McQcTask.job
- - - - ORPHANS REMOVED - - - -
HKLM-Run-C:\WINDOWS\system32\kduxh.exe - C:\WINDOWS\system32\kduxh.exe
MSConfigStartUp-BearFlix - C:\Program Files\BearFlix\BearFlix.exe
MSConfigStartUp-BitTorrent - C:\Program Files\BitTorrent\bittorrent.exe
MSConfigStartUp-BlazeServoTool - C:\Program Files\BlazeVideo\BlazeDVD 5 Professional\MediaDetector.exe
MSConfigStartUp-DAEMON Tools Pro Agent - C:\Program Files\DAEMON Tools Pro\DTProAgent.exe
MSConfigStartUp-Free Download Manager - C:\Program Files\Free Download Manager\fdm.exe
------- Supplementary Scan -------
FireFox -: Profile - C:\Documents and Settings\Mike\Application Data\Mozilla\Firefox\Profiles\zyovmwla.default\
catchme 0.3.1361 W2K/XP/Vista - rootkit/stealth malware detector by Gmer, http://www.gmer.net
Rootkit scan 2008-08-05 23:15:55
Windows 5.1.2600 Service Pack 3 NTFS
scanning hidden processes ...
scanning hidden autostart entries ...
scanning hidden files ...
C:\DOCUME~1\Mike\LOCALS~1\Temp\RGI5E.tmp 7075 bytes
C:\WINDOWS\system32\drivers\Olfv55.sys 124928 bytes executable
"C:\\WINDOWS\\system32\\kduxh.exe"="C:\\WINDOWS\\system32\\kduxh.exe"
Completion time: 2008-08-05 23:20:27
ComboFix-quarantined-files.txt 2008-08-06 03:19:25
Pre-Run: 87,672,279,040 bytes free
Post-Run: 88,271,028,224 bytes free
218 --- E O F --- 2008-06-20 07:01:30
HIJACK THIS LOG IS NEXT
HiJack This said:
Scan saved at 11:29:35 PM, on 8/5/2008
Running processes:
C:\WINDOWS\System32\smss.exe
O4 - HKLM\..\Run: [Malwarebytes Anti-Malware (reboot)] "C:\Program Files\Malwarebytes' Anti-Malware\mbam.exe" /runcleanupscript
End of file - 8153 bytes
Ouch...you had some Rootkits and Trojan backdoors. I hope you understand the true
power of them stealing your data. There are identity thefts today, stealing your CC numbers and passwords...Please stick to Computer Forum until we tell you you're clean.
Download Avenger, and unzip it to your desktop or somewhere you can find it. (Do not run it yet).
Note: This program is for use on Windows XP 32 bit systems only, and must be run from an Administrator account.
  • Open a Notepad file by clicking Start > Run and typing Notepad.exe in the box, click OK.
  • Click Format, and ensure Word Wrap is unchecked.
  • Copy and Paste the text in the box below into Notepad.
  • Now save the file as RemoveFiles.txt in a location where you can find it.
Files to delete:
Folders to delete:
Note: the above code was created specifically for this user. If you are not this user, do NOT follow these directions as they could damage the workings of your system.
Start Avenger by double clicking on Avenger.exe.
  • Check Load script from file:
  • Click on the folder symbol below and to the right, and browse to RemoveFiles.txt.
  • Double click it to enter it into Avenger.
  • Click the green traffic light symbol.
  • You will be asked if you want to execute the script, answer Yes.
  • At this point you may get prompts from your protection systems, allow them please.
  • Avenger will set itself up to run the next time you re-boot, and will prompt you to re-start immediately.
  • Answer Yes, and allow your computer to re-boot.
  • Upon re-boot a command window will briefly appear on screen (this is normal).
  • A Notepad text file will be created C:\avenger.txt.
  • Copy and Paste it into your next post please.
Now open your HijackThis again. Find and place a check next to these entries:
  • R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyOverride = *.local
  • O24 - Desktop Component 0: (no name) - http://www.protrade.com/
  • O24 - Desktop Component 2: (no name) - http://moola.com/
Now click Fix checked. Reboot your computer again.
In your next reply, please post a fresh HijackThis log and the Avenger log.
AVENGER
Logfile of The Avenger Version 2.0, (c) by Swandog46
http://swandog46.geekstogo.com
Script file opened successfully.
Script file read successfully.
Backups directory opened successfully at C:\Avenger
Beginning to process script file:
Rootkit scan active.
No rootkits found!
File "C:\WINDOWS\system32\epfforii.tmp" deleted successfully.
File "C:\WINDOWS\ST5UNST.EXE" deleted successfully.
File "C:\WINDOWS\ST5UNST.000" deleted successfully.
File "C:\WINDOWS\system32\xfcodec.dll" deleted successfully.
Folder "C:\Program Files\Viewpoint" deleted successfully.
Completed script processing.
Finished! Terminate.
FRESH HIJACK THIS LOG
Scan saved at 11:36:50 AM, on 8/6/2008
Running processes:
O4 - HKLM\..\RunOnce: [Cleanup] C:\cleanup.exe
End of file - 7983 bytes
I appreciate these helpful instructions. Thanks!
Wait for ceewi1 or Punk or Gamemaster to come back because they will fix the problem as they have higher training than some of us, so just pls be patient.
Still have pop ups with...porn images and warnings?
That's somehow unbelievable, lol.
  • Open HijackThis.
  • Click on Open the Misc Tools section.
  • Look under System tools.
  • Click on the Open Uninstall Manager... button.
  • Click on the Save list... button.
  • It will prompt you to save. Save this log in a convenient location. By default it's named uninstall_list.txt.
  • Notepad will open. Please copy and paste the contents of this log in your next reply.
See in this link details.
http://img.bleepingcomputer.com/tutorials/hijackthis/uninstall-man.jpg
