Help me with a new build.
spartikus
Hey guys haven't been on here in a while. Last time I built a computer for myself it was april 2008. I am selling my old computer and ready to build a new one. The last computer I had was an AMD chip computer. I want to build an Itel rig this time can someone give me advice as to what motherboard cpu etc etc. I will be using this computer mostly for surfing the net etc but I do play games occasionally. My budget for the whole set up would be in the 700 - 800 dollar range. Thank you in advance.
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case ($109.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Sony Optiarc DVD Burner ($25.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118023
Microsoft Windows Vista Home Premium SP1 64-bit ($99.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
CORSAIR CMPSU-650TX ($94.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
CORSAIR XMS2 4GB (2 x 2GB) ($51.00)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145229
EVGA GeForce 9300 HDMI ATX Intel Motherboard ($129.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188035
EVGA 01G-P3-N959-TR GeForce 9500 GT 1GB ($69.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130395
Intel Core 2 Duo E7400 Wolfdale 2.8GHz ($119.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB ($74.99)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Total: $776.92
Total: $776.92
Nice make man
N3crosis build nice too. Quad system cheaper than the Dual Core I put together.
A couple good options though, to mix and match with maybe. :)
So should I go quad core? Also I am hearing that the 775 socket is on its way out should I try to get a Mobo with a different socket? Thanks for all the help thus far.
You'll be fine for quite some time with a socket 775. The 1366 just came out so it's not like the 775 will disappear overnight.
I would go with the quad, definitely.
hey guys another question no matter which mobo i get intel or amd can i take my old video card out of my computer and use it in the new one its a evga 8800 gt the person i am selling my old computer to won't need the video card i think the video card on the mobo would suffice for them?
Just make sure to tell them that you are taking out the 8800gt before you sell it to them;)
Also what are some good video cards now days I am used to Nvidia hence the 8800 Gt in my last computer but how are ATI and which ones would be good choices if I chose to buy another video card instead of using my old one?
