computerstu
Currently using AVG which is OK, but looking for something a little better. Thanks.
+1Avira
Just unistalled AVG, will download Avira now. Thanks.
Tisk tisk tisk...Never a good idea.
ALWAYS make sure you have the new software first.
Now you're browsing around the internet trying to find links to Avira unprotected.
Heh, going to a download site getting an antivirus software isnt going to cause you to get a virus unless you dont use the official avira site... Personally speaking, half of the time i dont install an antivirus for 2-3 weeks after i reinstall my os.Tisk tisk tisk...Never a good idea.
Well, for one if your getting avira you should type www.avira.com into the address bar, two, if your using firefox or the latest version of IE, its going to alert you before anything is downloaded.Exactly.
All it takes is one bad click and you're done.
It's irresponsible to suggest it's "ok" to not use A/V software and browse the internet.
I would maybe risk it, but I have Vista with UAC turned on...
Ill just stay neutral on the issue. As long as the user has some technical knowledge and common sense, then i wouldnt see too much of a problem. If the user is a complete "noob" so to speak, then i highly wouldnt recommend browsing without protection.You're assuming some level of common sense, and that the user is running
said current software.
I wouldn't assume anything when advising others.
Someone that's less knowledgeable might click on that notifier.
Anyway, like I said, it's not a good idea.
I never said you couldn't get away without running A/V software, but I certainly wouldn't recommend it or advocate it.
I don't, seeming I supplied the free Avira link on Post#2i agree
