What to cut in this build to get 1500$ budget max?
daka123
intel i7-920 cpu
OCZ GameXStream OCZ700GXSSLI 700W ATX12V
EVGA 896-P3-1171-AR GeForce GTX 275 Superclocked Edition
ASUS P6T Deluxe V2 LGA 1366 Intel X58
Western Digital Caviar Black WD5001AALS 500GB 7200
OCZ Gold 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
ZALMAN CNPS9900LED 120mm 2 Ball CPU Cooler
NZXT Tempest case
Im in canada and i will buy the parts from ncix.com but with the shipping and taxes this build is 1750 i need to cut something so i can get 1500$ max.
To start, scrap the GTX 275 and get a 4870.
6GB of ram is overkill unless you have 64-bit o/s
Other than that, nice choices!
what he said. Or you could go to newegg.ca and save a ton of money...
For 1478.92 + shipping, - $60 mail-in-rebates, which comes to about $1450, you get everything on your list except the PSU (I got you a corsair 750W), hard drive (Western Digital Caviar Black 640GB instead) and the case (Thermaltake V9). Here is the list:
Hard drive
Corsair 750
OCZ Gold 6GB DDR3 1600
Asus Mobo
Core i7 920
Zalman 120mm cooler
Thermaltake V9
And of course you can shop around, I don't know, your PSU may be cheaper then the one I grabbed, then you save there. Smaller hard drive is hardly worth it, maybe $10. Enjoy ;)
