Enjoi
banned
I have a BFG 8800GTOC (Factory overclocked to 625) and it has been getting insane temperatures. It has worked fine for about 2 years now, not a single problem. However today when I was playing Operation Flashpoint 2, my screen went black and the monitor said it was going to sleep. I thought maybe it was a fluke, so I restarted and continued playing. Same problem happened. I immediately suspected temp problems so I downloaded an entire arsenal of stress tests/ temp monitor software and started checking things out.
Whenever I started the tests, the card was idling at around 85C. I took it out, blew some dust off and did a visual inspection of the card. Everything seemed ok. The dust blowing helped temperatures a bit, but not much. I got my old thermaltake fan back from my roommate and put it on the front of my case, and this lowered temps about 5c.
All of my other temps, CPU, system, etc, are fine. Cold even. But the video card is cooking itself. I have lowered the temps a small amount with the extra fan and dust removal, but during games I still go above 100c. The highest I have hit (since I started monitoring) was 108c. I know it is just a matter of time before the card commits suicide if things continue like this. The fan on the GPU is working fine... no obstructions or anything like that.
What could cause a video card to massively overheat like this, even though the fan is still running and I have good case cooling?
I tried reinstalling drivers. I am at 191.07 currently (The latest)
Not sure if system specs would help, but they are:
Asus P5K-E Wifi/Solo AP
Core 2 Duo E8400 @ 3.0 (Not OCd)
BFG 8800GTOC (Factory overlocked)
4 gigs 800mhz DDR2
Running XP 32 bit with SP3
4 gigs 800mhz DDR2
