Wow. BS. You said your Linux box run idle with 10% RAM used, and I asked how much total RAM, now you say it's just a VM?
Oh, that's right. You're the same person that said Windows 7 wasn't that great, when you only tried it in VM...
Do you not have enough resources to dedicate a computer to testing various OS's so you can back up your "claims"?
No, no, no, no, you aren't reading what I say right or maybe I didn't explain it fully. I said I have no current data off the top of my head because my current Linux install is a VM. However, I do have older Linux boxes on say 4 year old hardware that run at least 10 times better than Windows XP does on it.
Every modern OS should run fine at a basic level in a VM, period. I have VMs of XP, 2000, Linux, 98, DOS, and so forth and all of them work fine. I am not gaming in them. Hell, windows 2003 server works fine in a VM, as I have used it many times to do demos. If you go to a Microsoft road show, they run all the OSes off laptops and VMs, and they are doing live demos. To say that a VM is not a valid test of an OS is an understatement. I saw a WDS demo at a MS roadshow that was running in a VM deploying 3 VM images to two laptops. It was actually quite impressive how it ran, and it was pretty responsive and these were laptops.
The fact that Windows takes up so much HD space, and takes the most minimum resources to run is that it is the most bloated OS out there. Do you need 4gigs of RAM? On a Windows box, sure most likely you do.
If you do anything CPU intensive on your machine you probably need around 4gigs, anything above 4gigs is probably overkill, even for hardcore gamers. If you are just using your Windows box for web surfing and basic office type applications then 2gigs should get you by fine. Then again, now we look at how Windows 7 and Vista really only runs well on basic usage with 2gigs of RAM, where every other OS out there can do the same with 1gig of RAM.
This is why I don't like benchmarks because they don't reflect real world performance. There is no control benchmark or control system to compare the benchmarks too and even if you score 4,000 higher 3Dmarks than say your neighbor, your neighbor can possibly run the same game at max settings with their computer as long as the specs are similar.
So, how do you really justify using 4gigs of RAM? Well, you would need to qualify yourself as a user, and assess what you do and see if you really need 4gigs, or more than 4gigs. Your hardware configuration and your OS are factors in making this decision. More RAM is not always better RAM either.
