Build me a Gaming Rig! £1000 budget
Joehelsing
I don't want to spend more than £1000 on parts. You do not need to include the monitor, keyboard, mouse or Operating system. Just the hardware.
What parts would you recommend?
jamesd1981
well for a start why dont you look at either quad core or intel i5 cpu and a ddr3 graphics card with 512 or even 1gb onboard and id say 850 w psu and plenty of brand name ram like crucial etc ?
Shane
Super Moderator
EDITED....
Intel Core i7 860 2.8GHz 8MB L3 Cache Retail Boxed
http://www.ebuyer.com/product/172754
ASUS Rampage II GENE Republic of Gamers X58 Socket 1366 8 Channel Audio MATX Motherboard
http://www.ebuyer.com/product/162039
OCZ 6GB (3x2GB) DDR3 1600MHz Triple Channel Memory Kit for i7 Motherboards CL8 1.65V
http://www.ebuyer.com/product/158392
PowerColor HD 5850 1GB GDDD5 Dual DVI HDMI Display Port Out PCI-E Graphics Card With Dirt 2 Game
http://www.ebuyer.com/product/175714
OCZ 700W Mod XStream Pro PSU - 2x PCI-E 6x SATA
http://www.ebuyer.com/product/152008
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
http://www.ebuyer.com/product/173804
Coolermaster CM690 Dominator Black Mid Tower Case - No PSU
http://www.ebuyer.com/product/131551
LiteOn IHAS124-19 24x DVD±RW SATA DL & RAM Internal SATA Black Bare
http://www.ebuyer.com/product/176026
Let the guys check it over first though....
jamesd1981
great system but he said he didnt need an os so your actually within the budget but i notice there no psu with the case so he would need a psu aswell.
Stoic Sentinel
I was thinking more pentium i7
You mean a "Core i7?" Are you referring to the fact that the older CPUs Intel released were the Pentium D and the Pentium III and IV?
****EDIT***
PSUs that come with the case are generally shit anyways. And besides, Neva already picked out a PSU.
Joehelsing
Awesome setup, but it would be under £1000 because you dont need to include the windows 7 xD
I'm intrigued about that graphics card though, ive never heard of it.
Shane
Super Moderator
Well ive actualy edited my orig post and made it within budget...if he doesnt need an os then he can take the windows 7 off the list and then it will be even less :)
:rolleyes: I have included a PSU in my list....its the OCZ 700W :)
jamesd1981
oh yeah soz didnt see the psu well within budget for a great system then although if the os you have isnt already win 7 id seriously consider the extra for it would be a shame to waste a system like above with anything less than win 7
Joehelsing
My mate can sort me out with Windows 7 Ultimate so i'm okay for that. Really my overall budget is £1200 but that is to include gamind headset, mouse and keyboard which ive already picked out. The setup right there looks awesome, all i gotta do is whack in a DVD drive
Shane
Super Moderator
It would be a great gaming pc,But like i said wait to se what everyone else thinks of the build list first..they might make some changes.
Il edit my first post...so the list is what they see first.
Joehelsing
I wont be building it for another month or 2 so im basically doing as much research as possible. I want a MACHINE not just a machine. :D
Shane
Super Moderator
ohh its not just a machine.....Its a BEAST :p
Ive took off windows and added a Writer to the list...youl have to re-calculate the final cost as for some reason my list on ebuyer has gone :cool: :D
jamesd1981
that 2nd motherboard is unreal can handle up to 24gb ram WOW ! is there any limit to what win 7 64 bit can use i mean if say you put the max 24 gb in it could you use all of that ?
Shane
Super Moderator
Joehelsing
It's all good to know but I think 6GB RAM will be sufficient for the time being xD
I guess in the future it makes it easy to upgrade.
Stoic Sentinel
Yep, 6GB should hold you out for a few more years. I'm sticking with 4GB, by the time I need more, I'll probably just make a whole new build, because I'll be working by then :D
