ErikAlbert
Many users have a reboot, that doesn't do anything, except launching Windows (with or without problems).
My reboot (cold or warm) is totally different.
1. Any change in Windows (+ Registry) or Third Party software installed on my computer is removed/undone during each reboot.
Which means my system is always working properly, like it was installed the very first day.
2. Any software, I installed for testing is removed completely after reboot without any trace.
Most users use Windows Add/Remove Programs, which uses the uninstall program of that software. The final result is always an incomplete uninstall, which means that your harddisk has leftovers in folders and Windows Registry or somewhere else. The more you install/uninstall softwares, the more garbage you get on your harddisk.
Most users try to remove these leftovers by using all kinds of cleaning softwares, but they don't do a very good job.
3. Any change or any mistake by myself is gone during each reboot.
I can remove any software by deleting its folder or change its settings on my computer. This can happen accidently or intentionally by myself or an angry malware or another person.
I only have to reboot and my deleted software is back and settings are restored.
4. Any discovered and undiscovered malware is removed during reboot.
I use 3 non-security software to accomplish this : FirstDefense-ISR + Anti-Executable + Sandboxie, but FirstDefense-ISR is the most important one.
None of these 3 softwares know what malware is or don't even recognize it, nevertheless they remove any installed malware on my computer during each reboot.
Most users remove malware with a bunch of AV/AS/AT-scanners, but none of these scanners do a very good job and they certainly don't remove undiscovered malware.
That's why most users still get in trouble with all kinds of problems caused by malware. I don't need to prove this, each computer-forum contains posts of malware-victims, including this forum.
Wouldn't you like to have such a computer, that works properly everyday, year in, year out ?
I'm not even a computer-expert and used forums to ask questions like "How do I do this and that." They didn't even know why I asked these questions.
I just used the right softwares and used them in a good way and combined them well.
The rest was nothing but logical theoretical reasoning and it works during the last 5 years.
I don't know much about computer, that's true, but that doesn't mean I'm stupid.
