EVGA boards SUCK. I've disliked every one I've owned.
ASrock X58 extreme is THE best bang for the buck board and comes in under your max budget-
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157163
Otherwise, gigabyte is the best if you can swing the extra money. But really the ASRock board has every feature the gigabyte does pretty much.
i thought ASrock was going out of business, and ive heard that there customer service sucks. btw evga have outstanding customer service not to mention lifetime warrenty.i would have to go with what joh06937 recommended which would be the gigabyte.
ASRock = Asus.
Asus = Largest supplier of motherboards in the world
ASRock aren't going to be going out of business any time soon all the time they are still making money, which they are. And look at Asus tech support, it is brilliant to say the very least. I wouldn't turn down an ASRock board, especially if I was presented with the option of ASRock or EVGA
Uh, I've seen that stated alot on the internet, truth is Foxconn produces more motherboards/logic boards than any other manufacturer out there(don't forget the OEM segments as well, they OEM the boards for alot of manufacturers). Plus they make a majority of the microsoft/apple/sony/nintendo hardware just to name a few...
And as stated earlier, ASRock is the budget sector of ASUS, they are not equal, ASUS branded boards are made to a higher spec using higher end components.
I just love how all the people in this thread bashing ASRock have never owned one. This X58 extreme does not suffer in quality. ASRock used to be known for having inferior quality, yes, but once again that was back in the socket 775 era. Now with the P55 and X58 boards ASrock is every bit as good as Asus or gigabyte.
I don't know about as good. On paper maybe, but they lack the quality that Asus boards do because of cheaper components being used in some places.
steer clear of asrock unless your desperate and willing to take the chance the board will be flakey and need to be RMAed
Nice bandwagon jumping there. First you say asrock is pretty good, then after the bashing by other members all of the sudden it's ''well, they do have cheaper components and lack quality blah blah blah''
I didn't say they were bad, I just said they weren't, as you claimed, as good as Asus boards. They are still good boards, but lack the quality components that Asus boards have (generally)
