As AMD have less quality than intel?
Schoolwork, games but not really new games, I play alot of old games. I say the LGA 1156 socket motherboard is compatible with the newer cpus, so it's upgradeable. How much do you think a computer with a i3 would be without any bells and whistles.
$250?Too high.... What could I get for less than 250?
Agree with fastdude. Here is other component you could consider
COOLER MASTER Elite 430 RC-430-KWN1 Black Steel / Plastic Computer Case
FS, $35 MIR $10
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119227
PSU - Antec Basiq BP430 430W Continuous Power ATX12V Version 2.2 80 PLUS Certified Active PFC Power Supply, FS, $45, MIR $25
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176&cm_re=770-_-13-157-176-_-Product
AMD Athlon II X3 445 + ASRock M3A770DE AM3 combo, worth considering
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.547178
how bout this Power supply, it's cheaper.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817339009
$250?
The following PC will be very upgradable.
It's a challenge, but here goes:
CPU - http://www.newegg.com/Product/Produ...903&cm_re=Athlon_II_X2-_-19-103-903-_-Product - $59
Mobo - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157176&cm_re=770-_-13-157-176-_-Product - $55
GPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102907&cm_re=HD_4650-_-14-102-907-_-Product - $25 w/rebate
RAM - http://www.newegg.com/Product/Produ...194&cm_re=2_x_1GB_DDR3-_-20-148-194-_-Product - $36
PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E16817341038&Tpk=StealthXstream - Overkill, but $40 after MIR and leaves plenty of room for future upgrades
Case - I would say Rosewill blackbone but that was out of stock so...
http://www.newegg.com/Product/Product.aspx?Item=N82E16811815004 - $30
Optical - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175 - $17
HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148395 - $40
Total - 302USD
If you wanted to save even more cash, then downgrade to a Sempron 140 (saving $25)
EDIT: He has a Graphics card?
Downgrade to what?
Yeah, I can pretty much guarantee that you won't find a LGA1156 mobo with an AGP slot.I have an AGP graphics card, is an AGP slot rare?
The Sempron 145. It's a step below the Athlon II series, single core, but is still socket AM3 (AMDs latest socket). Fine for basic computing, plus has a low TDP (Heat/Power Consumed). But it's slower than the processormentioned above (Athlon II X2/X3)
Look it up on www.cpubenchmark.netTrust me, the Sempron will be a lot faster than a 2.4GHz Northwood. It's clocked higher and performs noticeably better clock-for-clock. Having said that, I'd rather go for a dual-core. If you decide to go for a Sempron, however, I'd go for the 140 instead of 145. You only save a few bucks, but that extra 100MHz is insignificant anyway (less significant than your ~$4).
