fastdude
OK, so I've decided that AMD is the way to go if you're on a tight budget
I'd like a cool (looking and temperature-wise) PC; usage is light-moderate gaming, will be overclocking, won't be having a multi-GPU setup, would prefer a modular PSU; I've heard the ModXStream has very short cables, will that be a problem for me?
Please suggest alternative components or give general advice.
Note: Someone who owes me a favour has said they will pay all the shipping
D)
I could get the 212+ cheaper on scan but novatech is just down the road so...
http://www.scan.co.uk/products/4gb-...600)-non-ecc-unbuffered-cas-9-9-9-24-xmp-165v - 2x2GB DDR3 - £50
http://www.scan.co.uk/products/amd-athlon-ii-x2-260-dual-core-s-am3-32ghz-2mb-cache-65w-retail - Athlon II X2 260 - £50
http://www.scan.co.uk/products/asus...-sata-3gb-s-raid-micro-atx-vga#ProductSupport - Asus M4A78LT-M - £45
http://www.ebuyer.com/product/190138 - Sapphire HD5670 512MB - £60
http://www.ebuyer.com/product/179016 - Xigmatek ASGARD - £30
http://www.scan.co.uk/products/500-...aviar-blue-sata-300-7200-rpm-16mb-cache-89-ms - WD Caviar Blue 500GB - £30
http://www.ebuyer.com/product/190671 - LG LightScribe DVD-RW SATA - £15
http://www.amazon.co.uk/dp/B001GLFD...de=asn&creative=22206&creativeASIN=B001GLFD4U - OCZ ModXStream Pro 500W - £50
http://www.novatech.co.uk/novatech/prods/components/cooling/cpucoolers/RR-B10-212P-GP.html - Hyper 212+ - £20 (collect from store)
http://www.amazon.co.uk/120mm-Blue-...T1UC/ref=sr_1_6?ie=UTF8&qid=1291485409&sr=8-6 - 3 x 120mm Blue LED fans - £20
subtotal: £370
subtotal: £370
