Final build list, would appreciate review! :D
millz777
So with help from the last thread i have this hopefully final list ???
any advice on a monitor people? :D
preferably 19-22" around £100?
is this one any good? (HP 2010i 20" Widescreen LCD Monitor - £119.99 )
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail [BX80605I5760] - £139.99 OVERCLOCKERS
Asus P7P55-M P55 Express Chipset (Socket 1156) DDR3 microATX Motherboard [90-MIBAW1-G0EAY0K] - £84.49 overclockers
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit - £58.74 overclockers
Cooler Master GX-Series 650W Power Supply Unit 80 Plus - £54.99 AMAZON
HIS ATI Radeon HD 5770 1024MB GDDR5 PCI-Express Graphics Card [H577FK1GD] - £99.99 overclockers
1TB Western Digital Caviar Black Hard Drive - HDD - £65.51 Aria Pc
LG GH22LS50 22x DVD±RW SATA ReWriter Lightscribe Drive - Retail - £16.44 overclockers
Coolermaster CM 690 II Advanced Pure Black Gaming Midi Tower Case - £73.19 Aria
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1156 / 1366) - £18.99 - Overclockers
Total £612.33
Total £612.33
100$ for a screen?! You can't get anything for that in Norway.. :(
Anyway.. Check if your items can fit in a Fractal Design Define XL. :)
One more thing! Get a SSD for your OS. :D
Im Actually pushing it a bit on the budget :(
anything to bring it down without bringing the performance down much would be great? any ideas?
Btw im going to be using it for Editing HD material in After Effects :good:
Check out combodeals at Newegg.com
Oh, didnt notice that it was Euro. For 800 NOK you can get something in Norway, atleast
1 Euro ~ 8 NOK
Looks good!!
The caviar black is really fast. not far off my vertex.
The only thing i dont like about it is it's loud and can be annoying.
would recommend it though for performance!!:good:
Looks good!!
Yh (y)
I need to try and bring down the price a bit though :/ if it's possible without downing the performance much :/
ive got the os sorted so thats not a problem.
do you see anything that can be changed for something cheaper but similar in performance?
It's all right. It's got good airflow and plenty of spots for fans, but not a lot of options for cable management at all. If you want sub-£50 cases, I'd look at these:
NZXT Beta EVO- great buy at £35
http://www.scan.co.uk/products/nzxt-beta-evo-black-mid-tower-case-w-o-psu
XClio Nighthawk Extreme- Mobo tray from the NZXT Gamma, but with a better fan configuration and some sort of gizmo on top.
http://www.scan.co.uk/products/xcli...-tower-case-black-10-front-bays-18cm-side-fan
CM Centurion 5 II and Gladiator 600- More or less cheaper versions of the Storm Scout
Centurion 5 II- http://www.scan.co.uk/Products/coolermaster-centution-5-ii-black-mid-tower-case-w-o-psu
Gladiator 600- http://www.scan.co.uk/products/coolermaster-gladiator-600-black-mid-tower-case-w-o-psu
Casecom 9188, 6988, and 6788 (all of them are similar to the NZXT Gamma/Rosewill Challenger)
9188- http://www.ebuyer.com/product/205157
6988- http://www.ebuyer.com/product/205154
6788- http://www.ebuyer.com/product/172779 (identical to the Challenger)
However, If you can afford the extra dough, I think the HAF 912+ would be the best for quality/price:
http://www.scan.co.uk/products/coolermaster-haf-912-plus-black-mid-tower-case-w-o-psu
Just ordered Everything as shown below -
Antec High Current Gamer 520W Power Supply - £59.99
MSI ATI Radeon HD 5750 1024MB GDDR5 PCI-Express Graphics Card - £82.24
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) [HD103SJ] - £40.98
Casecom 6788 Black Mid Tower Case - £28.99
LG 21.5" W2246S-BF 16:9 Wide LCD Monitor 1920x1080 5ms 1000:1- Black - £99.99
Arctic Cooling MX-3 Thermal Compound (4g) - £6.99
AROUND £637.83
