Well, you already have a decent CPU. Now save up for everything else you need.
So basically I can't play my game now lol... Is there not any aftermarket heatsink that will mount on my motherboard?
I looks like the Intel mounts on my Dell Optiplex's.Just guessing here, did a little research using google and I found where they actually use intel heatsinks even on amd processors. Does anybody think that a screw-in 775 heatsink would work? I'm thinking it might.
Kadan,
Measure the distance between the holes and let us know. I have to find one of my extra heatsinks and measure it.
Edit - Looks like they are roughly 2 7/8" apart.
Now the question is, what does he do? Find one that just screws in, or replace the back mounting bracket with the new heatsink?
On load that's fine. It's designed to run that hot.
75-80 is on the high side.
Kadan,
Are you savvy enough to remove the motherboard from the case to put in a different backplate? If not, you'll have to take it in to computer repair shop and have them put in a good aftermarket heatsink. Or you'll have to find a better screw-in type heatsink.
The heatsink in my Optiplex 745's are huge with a fan and have shrouds to pull air in from outside the case.And u don't think there's a good enough screw in out there?
Do you have a pic of your original heatsink/fan ass'y?
