First Build--Everything Look OK?
Also. I'm getting the gpus a little wile after everything else. Am I going to be able to game at all with just the integrated graphics?
I'd go for a single 670 because then in the future you can add another 670 so then you'd have two in SLI and that would definitely be faster than two 570s.
Is evga better? I didn't think of just getting one epic card instead of 2 darn good ones. Would SLI be better or should I just go with 1 card eitherway?
EVGA is a great brand, I'd definitely buy into their products.
One 670 would be cooler and less power hungry than two 570s and it would probably be just as fast. I'd get a single 670 like I said before. In the future get another one if you like and two 670s would definitely be much faster than two 570s.
Don't forget the 670 has more V-RAM too, 2GB vs the 1.28GB the 570s have. Even with two 570s in SLI you'd still have 1.28GB. The 670 would be better at playing future games at higher resolutions than two 570s would.
with cards this strong, you will be great with one and epic with 2. A 670 is more or less 2 570s and cheaper too with less energy used. Plus it leaves you open to a SLI 670 which would flat pown any 570 setup around.
Issue solved. Ill update the first post and bump this thread tomorrow to see what everyone else thinks. Not that I don't appreciate your guys help. I'm glad I waited to press the purchase button, you 2 have been great help.
Could you recommend a good brand of monitor. Like I said, I am planning on getting 3 23 inch monitors and I wanna do it up right.
for a normal person. 10. For someone that is good at following instructions and listening to videos. 3. For an electrical engineer -100. All depends on your understanding.
Its easy to build. There is literally nothing in a computer that will go in the wrong spot. And read the manual and you will have no issue at all.
My buddy said I would have a hard time with the drivers but I didn't know what he meant and he hasn't responded. Do you know hwat the heck he is talking about?
Also. Would it ever be necessary to get 32 TB of ram
Think you mean GB, not TB. Only reason to get 32GB is if you are using a lot of virtual machines at once, want to use a RAMdisk, or are doing some insane 3D rendering.
Wolfe, I noticed in another thread you said that you'd never buy from coolermaster again. What brand would you recommend/ what didn't you like about them/ would you recommend getting a different case then the one I choose?
