If you want I can quickly put my 2500K and RAM back to stock speeds and test for you?
2500K @ stock w/ 16GB RipJaws-X 1600MHz @ stock.
Big difference between 3.3GHz and 4.3GHz.
Below is the score @ 4.3
Thanks. To be honest, I am surprised at how well my system is doing compared to the newer hardware with a higher OC.
He will probably keep it for a while too. Im running 4.1GHz right now, but I can say for sure that I tap out on this board at 4.7 to 4.8 depending on the day. New build with a new cooler should clock better.Laquer Head is still leading the top!
You forgot Denther's score - Phenom II X4 955.
