Joseph Foster
Hey, just built my new system, first computer build too. Yesterday I was on it all day and it was running fine, I had installed my graphic card drivers, I was downloading and installing all my software, downloading a few game from steam etc. I must have been on for about 8 hours with it running great.
Anyway, I had just finished downloading and installing Hitman: Absolution, I loaded it up and used the in game benchmark on ultra settings, it looked amazing, got great fps. Then I jumped into the game, and that's when the disastrous happened...
... not two minutes into playing my monitor cut off and I had no screen however I could still hear the game in the background through y headset. I had no option but to hard boot and turning it on again. However when I turn it on I get 1 long beep, quickly followed by two short beeps. Nothing appears on the screen but I can hear windows logging in and my hard drives loading up.
All fans are working.
I've checked my manual but it doesn't tell me what the beep code means, however after going through the troubleshoot procedure and searching online I've concluded its possibly the graphics card - although others with similar problems/beep codes are reporting or been told its possibly the RAM, MOBO, CP, PSU... so I'm not 100% on it been the GPU.
Reseated GPU and RAM, but the problem persists.
List of hardware below. Any idea whats happening or what I can try?
Cheers.
HARDWARE:
Gigabyte GA-Z77-DS3H Socket 1155 VGA DVI HDMI 7.1 Channel Audio ATX Motherboard
Intel Core i5 3570K 3.4GHz Socket 1155 6MB Cache Retail Boxed Processor
Arctic Cooling Freezer 13 Intel and AMD Socket Heatpipe Cooling Fan
Sapphire HD 7950 3GB GDDR5 DVI HDMI Dual Mini DisplayPort PCI-E Graphics Card
Item: Corsair 8GB (2x4GB) DDR3 1600MHz Vengeance Memory Kit CL9 1.5V
Corsair TXM 650W Modular PSU
Seagate 1TB 3.5" Barracuda SATA-III 6Gb/s Hard Drive - 7200RPM 32MB Cache
OCZ 120GB Vertex 3 SSD 2.5" SATA-III 6Gb/s Read 550MB/s Write 500MB/s 85,000 IOPS
Samsung SH-222BB 22x DVD±RW DL & RAM SATA Optical Drive - OEM Black
Windows 7 Ultimate
EDIT:
Just taken out ram and started her up, got a continuous beep so I'm sure its not the ram thats the problem. Place RAM back in.
Took graphics card out and got the same beep - it must be the card. Gonna check wiring etc.
Could I try putting it in the other PCI slot to check its not a dodgy slot? The PCIEX4 one?
Cheers.
HARDWARE:
Windows 7 Ultimate
EDIT:
